$5 Stove Pipe - First Fire
   / $5 Stove Pipe - First Fire #1
crash325
Elite Member
Tucson AZ
New Holland TC-45
Just got my wood stove pipe replaced. Old pipe was a thin cheep one and only lasted 2 years.
New $5 pipe (Found it at Habitat for Humanity) is real thick & heavy, with a tight fully crimped seam. Just one step below the porcelain coated pipe. Used crimped elbows as they are almost as thick as the pipe. The Coffee can topper works better than the commercial rain hats & lasts about 2 years. This is the 3rd one that I have made and the first one painted. Maybe the paint will make it last a little longer.:)
Fitting it together and putting it up was one of the few things that has gone smoothly lately. :thumbsup::thumbsup::thumbsup:
Could not do all that and not build a fire. No it was not needed, just had to test the pipe. :laughing: Da!!! it works. :thumbsup:
So on the cool mornings coming us now I can have a little fire. Am ready for the actual cold that is coming.
   / $5 Stove Pipe - First Fire #2
Good job on the pipe. :thumbsup:
Fire ?, thought you guys in AZ just used that for cooking ? :confused:
   / $5 Stove Pipe - First Fire #3
Crash,
always good to use the heaviest guage stove pipe and elbows (non-galvanized), it comes in different guages at the wholesale level, some stores don't carry the good stuff, find the supply co's if not.......
cheap stuff is probably 28 guage......IIRC good stuff is 18 or 20 guage.....heavier is definetly better....:thumbsup:
Some dummy forgot the pictures. When I find out who that was, they will be in big trouble.:laughing:
Will
When younger cold did not bother me. Now anything below 70 and I am cold. Am building a new stove, it's a cook / heat stove. Old one can be cooked on, but not the best for that.
Wdchyd,
Didn't measure the guage, but its in the 20 range. Maybe high teens.
   / $5 Stove Pipe - First Fire #5
For me, unfortunately even the heavier gauge pipe doesn't last more than 2 years. I feel better about using a heavier pipe, but it doesn't last that much longer.
   / $5 Stove Pipe - First Fire #6
What goes bad with them after 2 years?? I have been running the same stove pipe since I installed it 7 years ago. Pipe came from the local True Value hardware store, nothing special, it gets cleaned yearly. I heat soley with wood, stove runs 24/7 from early Dec to end of March with occasional firings in Nov & April to take chill off. Stove is a Vermont Castings Defiant Encore, w/cat, if that matters.
   / $5 Stove Pipe - First Fire #7
Oh, I see the pics now....
I was wondering how you could only get a few years, I was thinking you were using this pipe on the inside....
Your pipe looks good but around here the FD wouldn't approve on that type of pipe outside......I have stainless insulated pipe on the outside and the same stuff has been up since 1984.......
I like the coffee can idea too....
The answer to your question is in it. What kills stove pipe is moisture, by burning your stove 24/7 no moisture can form. Around here stove is only burned 3/4 hours a day. As it cools condensation forms inside and out side of the pipe. The cat also burns most of the creosote that normally forms and it adds to the corrosion problem.
To a smaller extent the type of wood burned makes a little difference.
   / $5 Stove Pipe - First Fire #9
We've had the same single wall pipe for 7 years with small fires, parents have had the same single wall pipe for 35 years now, small fires, no problems...
   / $5 Stove Pipe - First Fire #10
I like that redneck top, I mean the coffee can top, but it won't work for me. The birds, mice, and ring tail coons, etc. will move in during the year. One year something filled the entire pipe with twigs, I guess birds trying to make a nest. When I started a fire all the smoke came inside the cabin.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2007 Case IH 275 Tractor (A59814)
2007 Case IH 275...
207281 (A52708)
207281 (A52708)
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
1996 Timpte 46ft Hopper (A56436)
1996 Timpte 46ft...
