5' Tiller question
   / 5' Tiller question #1
bzimmel
Buford, GA
Kioti CK30
I have a question regarding my tiller. I have a Kioti CK30. At what speed should I be running my PTO when using the tiller? High or medium?
   / 5' Tiller question #2
What speed is the tiller designed for?
I think there are two "main" designs, 540 RPM and 1,000 RPM. For my 540 RPM I need to run my M4700 engine around 2,200 RPM.
Do you have something on your dash that says PTO speed?
   / 5' Tiller question #3
How many teeth on the (tiller) PTO spline?
6 usually means 540; 21 usually means more.
If it works well at 540 PTO RPM with engine at rated PTO RPMs (look for a mark on the tach/check user manual) and low ground speed (< or = to about 1 mph) then that's a good speed to run it.
Well, the tiller is a refurb bought from a local guy, so not sure what it's rated for. I will count the teeth.
Barn Wood Planter Box (A50515)
Barn Wood Planter...
John Deere 960 Culitivator (A50514)
John Deere 960...
JOHN DEERE 4440 TRACTOR (A51243)
JOHN DEERE 4440...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
Ford 1320 Tractor (A50514)
Ford 1320 Tractor...
Semi Roll-off 2 Axle Trailer (TITLE) (A50774)
Semi Roll-off 2...
