5' Tiller question
/ 5' Tiller question #1
bzimmel
Buford, GA
Kioti CK30
I have a question regarding my tiller. I have a Kioti CK30. At what speed should I be running my PTO when using the tiller? High or medium?
/ 5' Tiller question #2
What speed is the tiller designed for?
I think there are two "main" designs, 540 RPM and 1,000 RPM. For my 540 RPM I need to run my M4700 engine around 2,200 RPM.
Do you have something on your dash that says PTO speed?
/ 5' Tiller question #3
How many teeth on the (tiller) PTO spline?
6 usually means 540; 21 usually means more.
If it works well at 540 PTO RPM with engine at rated PTO RPMs (look for a mark on the tach/check user manual) and low ground speed (< or = to about 1 mph) then that's a good speed to run it.
Well, the tiller is a refurb bought from a local guy, so not sure what it's rated for. I will count the teeth.
2012 Ford Flex Titanium (A64911)
2012 Ford Flex...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
SKLP SK-SSJ430 Rubber Track Jaw Crusher (A64912)
SKLP SK-SSJ430...
136" BULLDOZER ROOT RAKE (A65056)
136" BULLDOZER...
John Deere CX15 (A64911)
John Deere CX15...
1995 Fontaine (A64911)
