5' Tiller question
/ 5' Tiller question #1
bzimmel
Buford, GA
Kioti CK30
I have a question regarding my tiller. I have a Kioti CK30. At what speed should I be running my PTO when using the tiller? High or medium?
/ 5' Tiller question #2
What speed is the tiller designed for?
I think there are two "main" designs, 540 RPM and 1,000 RPM. For my 540 RPM I need to run my M4700 engine around 2,200 RPM.
Do you have something on your dash that says PTO speed?
/ 5' Tiller question #3
How many teeth on the (tiller) PTO spline?
6 usually means 540; 21 usually means more.
If it works well at 540 PTO RPM with engine at rated PTO RPMs (look for a mark on the tach/check user manual) and low ground speed (< or = to about 1 mph) then that's a good speed to run it.
Well, the tiller is a refurb bought from a local guy, so not sure what it's rated for. I will count the teeth.
2017 Ford F-250 Ext. Cab Knapheide Service Truck (A66736)
2017 Ford F-250...
2025 JMR Stump Bucket Mini Skid Steer Attachment (A66734)
2025 JMR Stump...
2022 New Holland Boomer 45 (A64911)
2022 New Holland...
3143 (A63117)
3143 (A63117)
PORTA POTTY (A67714)
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
