50 hour service question.... Desperately need help
   / 50 hour service question.... Desperately need help #11
I dunno Bird, It would have to shift the center of gravity slightly. Maybe I should post this on the safety forum /forums/images/graemlins/smile.gif
   / 50 hour service question.... Desperately need help #12
<font color="red">"For good air you should go to a local dive shop...It will cost you a little more but it is money well spent "
</font>
Please do not smoke while filling up! /forums/images/graemlins/wink.gif
   / 50 hour service question.... Desperately need help #13
I think I'll go the NASCAR route and use nitrogren (I think that is what they use) to minimize the air pressure build-up. When mowing you don't want that right front to build up too much air pressure and when cruising along at 5 mph you can where out that right front in a hurry. /forums/images/graemlins/grin.gif I don't keep a full time pit crew around when I'm mowing, so I would have to change the tire myself /forums/images/graemlins/shocked.gif
   / 50 hour service question.... Desperately need help #14
Still on the topic of tires - If the tire is flat, do you have to turn the flat part all the way to the top (12:00) or would 3:00 or 9:00 be okay? Maybe you could get a flat 4 times before you had to repair the tire? /forums/images/graemlins/tongue.gif
   / 50 hour service question.... Desperately need help #15
"nitrogren" hey you may be on to something...with air heating up and expanding as I mow I may have to readjust my deck
   / 50 hour service question.... Desperately need help #16
JMan: You should "check" the air every 50 hrs (more often if operating the tractor outside). If it is dirty, do a complete air change and replace the stems. If it is not dirty, do it anyway. Use only replacement air run through a compressor with a filter and dessicant cell (but not a lubricator). Don't have the valve stem at the 3 o'clock position if your tires are loaded w/ beet juice unless you are making Borscht.
When in doubt, don't pay any attention to your owners' manual. Those things were written by "airheads." /forums/images/graemlins/smile.gif
I think that that about covers it..... /forums/images/graemlins/wink.gif
   / 50 hour service question.... Desperately need help #17
If I put helium in my tires, will it be lighter on my yard and leave less ruts? /forums/images/graemlins/smirk.gif /forums/images/graemlins/tongue.gif
   / 50 hour service question.... Desperately need help #18
I don't think that you have enought to do. But yes get that winter air out and just put wind in.
   / 50 hour service question.... Desperately need help #19
Junkman, please be sure to dispose of the old air properly. Suggest you bring it to a licensed recycle center where it will be processed and probably shipped to the Far East. Then they will ship it back to us as hot air ready to fuel our elected officials.
Ken /forums/images/graemlins/smile.gif
   / 50 hour service question.... Desperately need help #20
<font color="blue"> I don't think that you have enought to do. But yes get that winter air out and just put wind in. </font>
In the summer, you need to fill it with hot air.
I know of a number of sources full of hot air... /forums/images/graemlins/shocked.gif
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
1998 BOMAG BW172D-2 SMOOTH DRUM ROLLER (A52707)
1998 BOMAG...
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2014 UTILITY VS2RA 53FT REEFER TRAILER (A57880)
2014 UTILITY VS2RA...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A57193)
UNUSED FUTURE MINI...
