50 hour service
   / 50 hour service #1
Coyote1
Hamden Ohio
GC1715
my 50 hour service is coming up i am not sure i found the transmission suction filter it shows it in the book with a bolt head.I found something in about the location but it has a allen wrench head. Is this it and do you have to remove the tire to get it out. It is a GC1715
   / 50 hour service #2
When I did my service on my 1710 I did not have to remove the rear tire. The screen was behind a large bolt, (left rear tire when sitting on the tractor.)
I didn't have a large enough MM wrench...I think I used a 7/8 wrench. Didn't have very much on the screen, rinsed it with kerosene.
   / 50 hour service #3
The new GCs might be different, but mine has the behind-the-rear tire suction filter as described above. It can apparently be removed without removing the tire, but having the wheel off does make it easier to get at it. Here are a couple of pics of my 50-hr service; the odd pic is showing the metal filings on a magnet, with the tractor behind. You can see where the suction filter came out in the background, just over the top of the magnet. Should be ready for my 500-hr service real soon. Filling the transmission on my 2310 is a LOT easier with the backhoe off, BTW.
Also, make sure you have a large enough drain bucket- there's a lot of fluid in there!
irivngj
   / 50 hour service #5
No. You can see where the strainer goes in this photo, from Irving.
The opening it threads into, is the dark circle, at the end of the magnet. It has a large hex head. located at the 8 o'clock position looking at the end of the left axle.
   / 50 hour service #6
Coyote, here are a couple of better pics, looking rearward over the mower deck, inboard of the left rear tire. It's a bit damp with oil.
   / 50 hour service
Thanks !!! I found it easier to see with wheel off.
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2012 Chevrolet Silverado 3500 HD Enclosed Knapheide Service Truck (A55973)
2012 Chevrolet...
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
