50 hr service for B3030
   / 50 hr service for B3030 #11
When my 50 hour service comes due (soon) i will change the front axle over to 80/90 gear oil, super udt for the hst and shell rotella 15/40 in the engine. It's nice to know i dont have to remove a rear wheel to service the hst, as you do on the B7500. The turf tires on my 3030 have 300 pounds of citris star each.
   / 50 hr service for B3030 #12
</font><font color="blue" class="small">( When my 50 hour service comes due (soon) i will change the front axle over to 80/90 gear oil, super udt for the hst and shell rotella 15/40 in the engine. It's nice to know i dont have to remove a rear wheel to service the hst, as you do on the B7500. The turf tires on my 3030 have 300 pounds of citris star each. )</font>
I thought about the Rotella-T...its a good oil in my opinion...but it wasnt in the proper "weight range" as specified...so I went with the SYN 5-40...which covered it alll.
</font><font color="blue" class="small">( Not using SUDT in your HST is a mistake. )</font>
I went by the temperatures set forth in the manual and for what I do and how cold it gets here standard UDT works just fine. If I was in the mountains or more north I would have gone with the extra SUDT. My tractor rarely works excessively hard and it is kept in a heated garage during the winter so having the fluid be "too Cool" is just not an issue for me.
As far as changing the fuel filter I can see in the bowl that it is clean. It is only on its 5th tankful with 52 hours on it and the fuel is run through an industrial 15 and 5 micron filter before it gets near the tank so it should be just fine for a long time.
The loader gets greased a little over 10hrs of operation as it does not do that much work normally.
All the bolts, pins, and linkages get a heavy coating of WD-40 to prevent rust and make removal easy.
Jeff
   / 50 hr service for B3030 #14
Sure it works fine or at least seems to be, but it still is a mistake that you did not use SUDT or a similar multigrade in your HST.
Woods Brushbull 720 3 pt Mower (A50514)
Woods Brushbull...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2017 Case 1150M Dozer (A50514)
2017 Case 1150M...
Cat 315l Excavator (A50514)
Cat 315l Excavator...
TRAILER AXLE (A51244)
UNUSED NORTHERN UTV-50 AG MIST SPRAYER (A51243)
UNUSED NORTHERN...
