5030 allis chalmers/ clutch housing/pwr steering
   / 5030 allis chalmers/ clutch housing/pwr steering #1
willyecoyote
5030 allis chalmers
recently while using the loader I broke the clutch housing(torque tube) i was looking for this part or a hinomoto crossover. also would like some info on spliting the tractor in-two(i.e. parts, gaskets, special tools, trade secrets). I figured while I'm in there imight as well change the clutch & pressure plate.....right? or is this a bad idea? Just a little info if you have a tractor w/FEL I would take & put a brace from the loader arms back to the rear axle(post experience wisdom)...it is cheeper & easier than replacing the clutch housing.
Also does anyone Know of an after-market power steering retrofit kit...I Know char linn makes some parts but haven't seen anything....HELP!
   / 5030 allis chalmers/ clutch housing/pwr steering #2
If you havent already, throw this one out on the grey market forum. They may be able to help source parts. it gets dicey with old Hinomotos.
   / 5030 allis chalmers/ clutch housing/pwr steering #3
When Hinomoto loaders are installed at the factory, they use bracing from the front bumper to the rear axle. They are not attached at the bellhousing at all. I put a NOS Yanmar power steering unit on mine with a little modification.
Eugene
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
377811 (A48836)
377811 (A48836)
Ford 3600 Tractor (A53117)
Ford 3600 Tractor...
2018 KENWORTH T270 SERVICE TRUCK (A51406)
2018 KENWORTH T270...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
