5030 allis chalmers/ clutch housing/pwr steering
   / 5030 allis chalmers/ clutch housing/pwr steering #1
willyecoyote
5030 allis chalmers
recently while using the loader I broke the clutch housing(torque tube) i was looking for this part or a hinomoto crossover. also would like some info on spliting the tractor in-two(i.e. parts, gaskets, special tools, trade secrets). I figured while I'm in there imight as well change the clutch & pressure plate.....right? or is this a bad idea? Just a little info if you have a tractor w/FEL I would take & put a brace from the loader arms back to the rear axle(post experience wisdom)...it is cheeper & easier than replacing the clutch housing.
Also does anyone Know of an after-market power steering retrofit kit...I Know char linn makes some parts but haven't seen anything....HELP!
   / 5030 allis chalmers/ clutch housing/pwr steering #2
If you havent already, throw this one out on the grey market forum. They may be able to help source parts. it gets dicey with old Hinomotos.
   / 5030 allis chalmers/ clutch housing/pwr steering #3
When Hinomoto loaders are installed at the factory, they use bracing from the front bumper to the rear axle. They are not attached at the bellhousing at all. I put a NOS Yanmar power steering unit on mine with a little modification.
Eugene
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
9202 (A50322)
9202 (A50322)
MISC WRENCHES (A53843)
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
