5030 "skidder" pics - the "tree-bota" in action
   / 5030 "skidder" pics - the "tree-bota" in action #1
CT_Tree_Guy
Platinum Member
Northwest CT
Kubota L5030HST
5030 \"skidder\" pics - the \"tree-bota\" in action
Hi all -
Here are a few pics of my 5030 in action (8 in all). It's set up specifically for use in tree removal, with a Bradco brush grapple on the front and an Implemax 4836RW grapple on the back. In 1 1/2 years and 540 hours, the Bradco has come off 3 times and the Implemax never.
I want to thank you all again for the help you all gave me in making the many decisions that went into this purchase. When I first came to this site 2 years ago, I knew that tractors had engines, wheels, and 3-point hitches. Now I have a machine that suits my needs nearly perfectly and has made my work a pleasure and my life better.
The extent of my gratitude is expressed in my post "Our 5030 - thanks TBN for all your help!". Please check it out if you can, it sums up how I feel about this site and all the people in it. I apologize for not joining in sooner, and hope that as a newcomer I was not too "familiar" in that post. I just feel a strong kinship to this bunch and am looking forward to getting to know you all better.
This first pic shows her picking up a 26" diameter, 10 1/2 foot red oak log that my chart tells me weighs 2,436 lbs. The Bradco weighs 800 lbs. for a total of over 3,200 lbs., so it seems the rated lift capacity of 1,874 lbs at bucket center is conservative indeed. This is with a Kubota quick-attach which I'm thinking of eliminating for some added lift, but my front axle might be of another opinion. I've boosted the relief valve setting to 2,500 or so PSI (the max is 2,560). It was at about 2,300 from the factory, and the boost made quite a noticeable difference.
In the pic I've grabbed a smaller oak log with the rear grapple to keep her butt on the ground. The Implemax grapple has a "heeling area" which allows the log (or entire smaller trees) to be lifted clean of the ground, so she's not really a "skidder". Very important for doing residential work. Plus, the 18" turf tires are very easy on all but the softest ground.
Re: 5030 \"skidder\" pics - the \"tree-bota\" in action
This one shows how the rear grapple works. The front grapple can pick up more weight than the rear, which might be good for about a 1,200 lb. log/tree, maybe a little more. The rear grapple also weighs about 800 lbs., making for really good balance. This allowed me to not have to fill the tires.
Here she is with a decent mouthful of brush, ready to bring over to the chipper. It can take even bigger gulps than this.
This is a closeup of the rear grapple, set down on the ground in "winching mode". You can see the heeling area. You just back up over the end of the log about a foot or so, grab it with the arms (they're about 4 feet long) and raise the 3-pt hitch - works great.
Close-up of the Bradco grapple holding the "fatty" from pic 1.
Close-up of the Implemax grapple showing the Warn winch. They did a heck of a job designing this grapple. The winch is tucked in out of the way, and the cable comes up and over a fairlead roller for a good high pull. The tongs set into the ground keep the front end from coming up. The winch also has a level winder on it and the cable always spools up nice and neatly, never had it "bird-nest" once.
   / 5030 "skidder" pics - the "tree-bota" in action #7
Great pictures Tree Guy. Thanks for posting them.
This shows the electrical joystick that controls the rear grapple. You push forward to raise the tongs, back to lower them, right to open them and left to close them. You can close/raise, open/lower etc. simultaneously, much more convenient than remote levers. The rocker on the top of the joystick will operate the CCM top link cylinder that I haven't put on yet. This will give the grapple arms even more range of motion for reaching around fatter logs. The joystick controls the 3 hydraulic solenoids that you can see in pic 4, behind the toolbox.
This just shows some good-sized logs that she's gotten out of the back yard, over to the driveway, ready for the log truck to pick up. (How did we do it before? I hate to even think about it). Once again she's earned her Amsoil /forums/images/graemlins/smile.gif
Anyway, thanks for bearing with another "proud papa", and thanks again for all your help - John
No prob HC, happy to share. Are you coming close to getting your 5030?
(Yikes, look at the time - I don't usually stay up this late but that took a while!)
2015 Tiger Trailers Inc. Gooseneck T/A Enclosed Trailer (A51692)
2015 Tiger...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
2019 FORD TRANSIT 350HD VAN (A53426)
2019 FORD TRANSIT...
Curry Bac Bottle, 4700 gal bottle with pump/vac  (A52384)
Curry Bac Bottle...
2004 Ferrara Pumper Fire Truck (A51692)
2004 Ferrara...
Skid steer auger plate (A50322)
Skid steer auger...
