5075E rear SCV leak
   / 5075E rear SCV leak #1
GreenBean
JD 5075E
I have a new 5075E with 10hrs on it and I noticed a hydraulic leak where the handle for the rear remote SCV inserts into the axle housing. More fluid seems to leak when I raise pull the handle up past the float position. I noticed that the bush hog pull-type does not stay raised as well while connected to the rear SCV. Please help
   / 5075E rear SCV leak #2
Welcome to TBN, GreenBean. Ten hours, huh? Well, that's a bit frustrating, I'm sure... One good thing about it, though - under warranty - and the onus in gonna be on your dealer to get things right.
I looked here for a parts diagram of your rear SCV - John Deere - Parts Catalog
Too bad it doesn't show an exploded view of the valve body. However, if I'd have to venture a guess; I'd bet that there's an O-ring just below the cap (with 2 bolts) that the shaft fits into at the top of the valve.
Should not be a difficult or too expensive a fix - IMO.
AKfish
After looking through parts catalog the leak is where the hydraulic oil supply line (14) inserts into the rockshaft there are two o-rings between the line and elbow(27) that inserts into the rockshaft. It leaks when using FEL, 3PH, and rear SCV. Anyone else have this problem?
New/Unused Quick Attach Seeder (A54865)
New/Unused Quick...
Paint Sprayer (A47477)
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
2014 PETERBILT 388 AUTO TRANSPORTER (A56129)
2014 PETERBILT 388...
