5105 making "clicking" noise like turn signal
   / 5105 making "clicking" noise like turn signal #1
andrewj
Platinum Member
South Carolina
JD 5105
5105 making \"clicking\" noise like turn signal
anyone know what this could be? thanks
   / 5105 making "clicking" noise like turn signal #2
Re: 5105 making \"clicking\" noise like turn signal
could be that you have a direct short and a relay is popping.
   / 5105 making "clicking" noise like turn signal #3
Could be a lot of things. But ,are You talking about a clicking noise while moving ? If so , check the torque on your wheel bolts . John
   / 5105 making "clicking" noise like turn signal #4
My 4010 makes a clicking noise when the parking brake is on.
Ralph
OK - more info - the clicking IS the turn signal sound....the turn signals don't work. (they did initially when the clicking started, now they don't). the hazard switch still does turn them both on though. The clicking stays on even when I remove the key. today, it made a buzzing sound like a weak horn trying to blow a horn sound.
Any ideas at all? Please tell me all I have to do is replace the turn signal switch...
any ideas at all? is there a relay I could just replace?
   / 5105 making "clicking" noise like turn signal #7
My 790 did something simular. and it was the battery had a short in it that was causing the voltage regular to go nuts and it clicked but if I remember it was only when the key was on.
I hope this helps.
Jim
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 14ft...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2014 Trail King TK50LP Equipment Trailer (A57453)
2014 Trail King...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
2015 Dodge Charger Police Car, VIN # 2C3CDXAT0FH817478 (A57453)
2015 Dodge Charger...
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
