5105 making "clicking" noise like turn signal
   / 5105 making "clicking" noise like turn signal #1
andrewj
Platinum Member
South Carolina
JD 5105
5105 making \"clicking\" noise like turn signal
anyone know what this could be? thanks
   / 5105 making "clicking" noise like turn signal #2
Re: 5105 making \"clicking\" noise like turn signal
could be that you have a direct short and a relay is popping.
   / 5105 making "clicking" noise like turn signal #3
Could be a lot of things. But ,are You talking about a clicking noise while moving ? If so , check the torque on your wheel bolts . John
   / 5105 making "clicking" noise like turn signal #4
My 4010 makes a clicking noise when the parking brake is on.
Ralph
OK - more info - the clicking IS the turn signal sound....the turn signals don't work. (they did initially when the clicking started, now they don't). the hazard switch still does turn them both on though. The clicking stays on even when I remove the key. today, it made a buzzing sound like a weak horn trying to blow a horn sound.
Any ideas at all? Please tell me all I have to do is replace the turn signal switch...
any ideas at all? is there a relay I could just replace?
   / 5105 making "clicking" noise like turn signal #7
My 790 did something simular. and it was the battery had a short in it that was causing the voltage regular to go nuts and it clicked but if I remember it was only when the key was on.
I hope this helps.
Jim
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
XCMG CV83PD (A53317)
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
