5220 Fuel Tank
/ 5220 Fuel Tank #1
bigdeereman
John Deere 5220
My fuel tank is leaking where the tank drain is located. The previous owner must have removed the factory drain. Does anyone know if the tank has standard or metric threads?
/ 5220 Fuel Tank #2
is it a cab or open station? I know on the open station fuel tanks the drain is on the left next to the rockshaft arm . should have a petcock 1/4 pipe, with a hose clamp around it. just threads into the plastic.
/ 5220 Fuel Tank #3
Not sure on the threads, but I had an issue with mine on my previous 5105. Wound up draining tank and replacing. Believe I installed with teflon and the clamp mentioned above.
/ 5220 Fuel Tank #4
According to JD spec's it's NPTF
Part Number: AT13740
Part Price: 2.58 USD
On Hand: 4 Check Other Stores
Description: COCK, DRAIN
Specification
Weight 0.07 LBS 0.03 Kg
Size 0.250
Thread Type NPTF
Height 1.083 IN
Handle Type LEVERWU
Finish
Note A
