5320 brake issue
/ 5320 brake issue #1
KeithyGeorge
G'day all,
I have a problem with my 5320. The brakes go very spongy almost non existent after using the PTO for while say more than 30mins. If the PTO isn't used the brakes are fine.
The brakes when the issue occurs come good after pumping them however then return to being not there.
I had this issue a while back and the tractor has had little use since
https://www.tractorbynet.com/forums...ng/421147-jd5320-541-fel-hydraulic-issue.html
thanks
Mark
/ 5320 brake issue #2
I had an issue just like this in my JD 5520 and it turned out to be a sticky rear remote lever. Why it affected the brakes I don't know. After trying lots of things, I wiggled the remote lever back and forth a little and problem solved. If you have a rear remote, try wiggling the lever.
/ 5320 brake issue
Thanks I will give that a try!
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
2012 CATERPILLAR AP1000E ASPHALT PAVER (A65056)
2012 CATERPILLAR...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2020 Ford F-150...
CHECO GREASE UNIT (A68842)
CHECO GREASE UNIT...
2026 323W Stand-On Mini Wheel Loader Skid Steer (A66734)
2026 323W Stand-On...
