540 RPM PTO @ 2600RPM
   / 540 RPM PTO @ 2600RPM #1
MacMurphy
Ok, got my new CK30HST and loving it, pictures soon I promise...
I have a few attachments and am learning slowly, I was interested in a previous post that stated the hour meter was based upon running time @ 2600 rpm...
My dealer told me, and I have my doubts, that to obtain a 540rpm at the pto I can either:
A) Set engine rpm to 2600 and set the rear PTO to the 540 position
or
B) Set the engine rpm to 1300 and set the read PTO to the 1000 position
Comments ?
Thanks
Murph
   / 540 RPM PTO @ 2600RPM #2
<font color="blue">A) Set engine rpm to 2600 and set the rear PTO to the 540 position
or
B) Set the engine rpm to 1300 and set the read PTO to the 1000 position</font>
It would depend on the implement your planning on using. In the US, implements in this size range, that operate at 1000 RPM PTO speed are few and far between.
In round numbers the formula above would appear to make sense. Figuring the 1000 PTO RPM's is also at 2600 RPM's, splitting the 2600 RPM's in half (1300) should also split the 1000 PTO RPM's in half. HOWEVER, if you're only operating at 1300 RPM you are only 300 to 400 RPM's above idle speed. I would say the tractor's operating performance would be seriously lacking at only 1300 RPM's.
Don
My guess was torque will be the problem at only 1300 rpm.
Murph
   / 540 RPM PTO @ 2600RPM #4
I believe on the CK30 you can only run it in 540 rpm pto @ 2600 because there is a stop on the pto lever that wont allow you to put it into 1000 rpm pto.
dean moore
   / 540 RPM PTO @ 2600RPM #5
My 3054 seems like the hourometer increases at the same rate regardless of rpm.
thx
Jim
   / 540 RPM PTO @ 2600RPM #6
</font><font color="blue" class="small">( I believe on the CK30 you can only run it in 540 rpm pto @ 2600 because there is a stop on the pto lever that wont allow you to put it into 1000 rpm pto.
dean moore )</font>
It's my understanding the 1000 rpm pto is an option in the USA.
Don
My CK30HST has the option of 540 or 1000...
Thanks
Murph
   / 540 RPM PTO @ 2600RPM #8
I believe the 1000 is for Mid PTO. Do you have a Mid PTO?
The hour meter in the CK30's and some of the other new tractors are a ture hour meter. They are not mechanical anymore and are electronic controlled. Engine must be running for them to work though.
   / 540 RPM PTO @ 2600RPM #9
<font color="orange"> I believe the 1000 is for Mid PTO. </font>
I thought Mid PTOs were 2000 RPM? /forums/images/graemlins/confused.gif
   / 540 RPM PTO @ 2600RPM #10
2000RPM is mid PTO, thats what I said right /forums/images/graemlins/wink.gif... I replied this morning before I was fully awake. Yes the Mid PTO is 2000RPM my typo error. I have yet to see a CK30HST with 1000 RPM. Hrmm I will have to do some checking.
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A51692)
2004 Pierce Tilt...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2010 Ford Focus Sedan (A51694)
2010 Ford Focus...
KSI Conveyor (A53473)
2015 Ford F-350 Dump Truck (A51691)
2015 Ford F-350...
