545 torque specs.
/ 545 torque specs. #1
brain55
Veteran Member
Brentwood, CA
Does anyone have the head bolt and connecting rod nut torque specs. handy for a 545.
Thanks,
Brian
/ 545 torque specs. #2
60 on the conecting rods and 115 on the head bolts but u have to do the head bolts at 90 then 100 then 115
/ 545 torque specs.
Awesome, Thank you. I meant to look this up this weekend and got busy with other things.
Brian
/ 545 torque specs. #4
on farmtrac 545 , 555 , 665 use a ford 4000 head gasket, works just fine, also check head with a straight edge, if you can get a 3000th feeler gauge under it get the block surfaced
