kthompson
Elite Member
- Joined
- Sep 12, 2008
- Messages
- 3,509
- Location
- South Carolina
- Tractor
- Kubotas B2710, M6800, L6060 cab, Volvo EC excavator, 2 ZTRs and various implements.
I have used each of the 3 styles of disk mentioned here.
To me hauling the disk shown will get old. It has to ride on the blades and regardless it will walk on any trailer placed on, wood or metal. Have never used a two gang disk like it but how are they for backing? That is the only way to unload.
I have never really notice a 3pth hitch or disk on wheels to be any difference in how hard to pull but have never had as large 3 pth disk as pull type. I like the 3pth for tight spots and cost less. Also the disk helps with traction as the weight is on the tractor. I like how much better a tractor rides with a pull type disk as the weight and most of the bouncing in removed. It does help at times to prevent bogging as the rear wheels have less weight but then here comes a heavy disk into a wet area. But you can lift the disk, lock it and unhock to pull with chain moving tractor to firming ground and pull it straight to rehook. Hard to do with 3 pth disk.
As to the claim about the older Case pulling such a disk and thinking a 25 hp CUT would do same, I think is way off. The old Case weighs so much more and has so much more traction. If you think the weight difference don't matter hook the two together with length of chain and the old Case probably would pull twice the hp of a CUT in 2 wheel drive, maybe 4 wheel drive. If you running load on pto only weight advantage is out the window.
I have a 27 HP CUT and have a 10 foot pull disk with 20 inch blades I pull with 68 hp 2 wheel tractor of about 7,000 lbs then with wheel weights and filled tires. That 10 foot disk cutting only about 7 inches deep is a load on that 68 hp running somewhere around 5 mph. (It is M6800 Kubota and normally run disk in high range 2nd gear. If I drop lower than 1st gear in high range not happy with results.) Now I could drop to a crawl and probably pull 12 or so feet depending on wheel spinning. But if you are crawling with a disk you are getting poor results. You do need it to roll the dirt, not slice it open to lay cable in the openings. There must be enough force in rolling the dirt to break it up and trash in it.
Of if you drop off the rear gangs over time you will find you are losing soil to area you are not disking as the rear gang brings it back where the front gangs throws the dirt out. If you go with front gang only, I would slow down on outside pass to minimize that.
