60-1 and 60H-1 Chain Size
   / 60-1 and 60H-1 Chain Size #1
Kubotafan
Nova Scotia, Canada
G1800AWS, B3030HSDCC, L3540HSTCC, JD710A
What is the difference between a 60-1 chain (as used on my snow blower) and a 60H-1 chain? My blower has a 60-1 chain and I was wondering if the "H" was a heavier chain chain and if it would run on the same sprockets. I know the connecting link is not the same for both chains.
   / 60-1 and 60H-1 Chain Size #2
G'day 60h will run where your old chain did it (60h) has got heavier side plates and i think from memory slightly heavier pins but the pitch and roller size is the same.
Jon
   / 60-1 and 60H-1 Chain Size #3
In some applications the wider links of the 60H chain cause clearance problems when replacing 60 chain. Check clearances between sprockets and supports, frames, etc. before converting. 60 offset and connector links will not work on 60H chain.
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
KUBOTA M125X TRACTOR (A60430)
KUBOTA M125X...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2023 Deere 325G (A60462)
2023 Deere 325G...
2014 Ford Flex SUV (A59231)
2014 Ford Flex SUV...
2004 CATERPILLAR D5N XL HIGH TRACK CRAWLER DOZER (A60429)
2004 CATERPILLAR...
