6000 4x4 burned oil filler cap
   / 6000 4x4 burned oil filler cap #1
turbinesurgun
oil filler cap came off and laid on manifold and melted. only 50 hours on machine. think warranty will cover if not how much money? thanks
   / 6000 4x4 burned oil filler cap #2
From past experience - Mahindra will furnish you with a new one at no charge. Judging by the postings on this forum with other owners, bent PTO shafts, kinked hydraulic fittings to the front steering cylinder, etc, have been replaced. In reality Doc, this is the first time I heard of this problem. Unless the cap was faulty, I would guess that it wasn't fully turned to the tightened position. This will be a cheap repair as far as Mahindra is concerned either way. They will want the old one back however. If the dealer is a distance away or an inconvenience for you to get it - they will send it right to your address.
all mine has is an o-ring to hold it in there is no tight or loose it has the breather tube on it is this the norm or do i have an oddball all you do is push it down in the hole right. it is on top of the valve cover.
   / 6000 4x4 burned oil filler cap #4
Your cap is normal. The filler cap fits adequately tight on mine. Haven't had that trouble. BobG in VA
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
2019 KOMATSU WA320-8 WHEEL LOADER (A51246)
2019 KOMATSU...
2023 John Deere S780 Combine (A53342)
2023 John Deere...
2005 John Deere L118 Automatic 42in Riding Mower (A51694)
2005 John Deere...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
