62" ON RAMP DECK TROUBLE
   / 62" ON RAMP DECK TROUBLE #11
Re: 62\" ON RAMP DECK TROUBLE
Excuse me for jumping in here but, doesn't your tractor carry your deck and the wheels only prevent scalping???
If so, then you may have these wheels set too low???
If not, sorry I interrupted the discussion.
   / 62" ON RAMP DECK TROUBLE #12
   / 62" ON RAMP DECK TROUBLE #13
I'm not sure if this is the appropriate method of setting the wheel adjustment, but mine are significantly above the bottom of the deck. This way when the deck needs to lift as I go around tree mounds (I have an otherwise flat property) the wheel barely hits the ground before the deck does.
   / 62" ON RAMP DECK TROUBLE #14
I to have mine set higher than the deck also. They are only to prevent scalping and not for the deck to ride on. Mine are pinned at the 6th hole.
Good Luck!
   / 62" ON RAMP DECK TROUBLE #15
I was reading other threads on this subject and someone mentioned that the front bracket that holds the deck should swing freely to help with the wheel problem, do others agree?
2011 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A56129)
2011 FREIGHTLINER...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
