That was my phone creatively helping me invent new words with it's imaginative auto misscorrect feature.
My fords have bunG DRAINS.. big 2" drains. I pulled those drains and used low pressure, pressure washer setting and blew out the transmission and rear end and hydraulics .
I then replaced those drains and filled the sumps up with a mix of diesel, alcohol and atf fluid. Any type of cheap atf, store brand, whatever. 1 quart per 5 gallons of diesel, and on the alcohol, a couple pints of 90% rubbing alcohol, or even denatured 100% alcohol.
Water and oil don't mix, but can form temporary and stable emulsions. The emulsion looks like a milkshake. The diesel helps wash the oily emulsion away as it is a petro solvent.. it will help dissolve the oil portion of the stable emulsion. Water is polar. Alcohol is a polar solvent. That's right.. alcohol will technically 'dissolve' water and carry it out in solution, vs suspension. The water/alcohol forms an azeotrope... and will have a modified evaporation rate and will not fall out of solution, but will evaporate evenly.
Thus your pressure wash drives the big sediments out, and then the flush grabs all the oily water.
For the engine, I just did the flush, no pressure wash. if all you filters are in place ont he engine, you shouldn't get too much sedimentation, if any in there unless the turbidity of the water was extremely high, making it look like cloudy water. If it was simply 'rising water' usually not much sediment is carried high.
