7 Blade Trailer Harness/Connector
   / 7 Blade Trailer Harness/Connector #1
Balazar
N/A
Has anyone made their own 7 blade trailer connector instead of buying the factory one that plugs into the factory wiring harness? What connector do you need to do this? here is an example of what I am talking about. TYM TRACTOR TRAILER SOCKET KIT
   / 7 Blade Trailer Harness/Connector #3
That’s probably the Europe version , it’s not the US rv seven pin socket
My Mahindra has the Europe type on it, can get the mating plug on amazon
It's just a 4 blade to 7 blade converter? That is all I need? I feel dumb. I also feel glad that I didn't pay $100 for one from TYM.
   / 7 Blade Trailer Harness/Connector #5
And if your getting a different version than what is common here it would be best to get a couple because I've had several plugs go bad.
   / 7 Blade Trailer Harness/Connector #6
Tractors generally are equipped with a 7 pin plug not a 7 blade plug that is commonly found on pick up trucks. The 7 pin is commonly seen on semi trucks. Note that the stop and turn signals are separated on a 7 pin but combined on the right and left channel for the 7 blade. Also there is no trailer brakes on the 7 pin.
Below is the common 7 blade plug. Note the differences in wiring.
The other end on the 12396410000 kit that OP lists is not a standard 4 pin trailer plug. It is some other plug design. $100 is not a bad price from TYM compared to tracing wire, finding a matching plug to the harness and fabricating the loom. The problem is that @Balazar will need an adapter if trying to use a 7 prong tractor with a 7 blade trailer.
Below is an example of an adapter.
   / 7 Blade Trailer Harness/Connector #7
And many of the tractors are wired the same as some foreign cars used to be and will need the converter for the tail/brake lights.
   / 7 Blade Trailer Harness/Connector #8
You can buy the 7 round pin to 4 flat as well.
   / 7 Blade Trailer Harness/Connector #9
This is what my Mahindra (TYM built) has as a seven pin trailer connector, Europe style “Type N”
Not the same as the US round seven pin connector
Also the mating plug can be found on Amazon or fleabay for a few bucks, I paid 4-5 bucks from Amazon
If the OP has this “Type N” and wants to go to a flat four pin, he can get the connector and make an adapter for a few bucks
I can post what the signal pin outs are for my tractor are but not sure if you’re TYM would be the same
   / 7 Blade Trailer Harness/Connector #10
Very common on the imported tractors;
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A43004)
2020 INTERNATIONAL...
New/Unused Pallet Forks (A44391)
New/Unused Pallet...
2017 Ram ProMaster City Van, VIN # ZFBERFAB0H6D37068 (A44391)
2017 Ram ProMaster...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
24in Tractor Backhoe Bucket BT4555 (A46877)
24in Tractor...
American Sanders Floor Sander (A45336)
American Sanders...
