Mowing 7' Finish Mower
   / 7' Finish Mower #1
retired007
New Holland 3930 Kobota Zd21 Mule 4010 New HollandTZ25DA
I have a 3930 with a 6' finish mower and am thing about a 7'. Would like opinions on advantages and disadvantages of the larger mower. Also would like to know your top four brands if you were buying.
Thanks
   / 7' Finish Mower #2
I have a 7 foot Frontier finish mower and it works very well.
They are avaliable thru your John Deere dealer.
www.buyfrontier.com
   / 7' Finish Mower #3
Pros on a 6ft I do not have something on the back of the tractor that is wider than the tractor. If the tractor can fit through, so will the mower and I do not need to keep reminding myself it is back there. I go in the same tire tracks on the next pass, so in my case I would cut more grass in the same time. Less grass matted down from the tires. All my garages are 9 foot wide. While 7 is smaller then 9, backing in with a 6 foot mower is an easier, then 7 foot. I rarely need ballast on the back, but when I do I use my mower as it weighs 700 pounds, again I do not need as much to remind myself it is back there. Easier to move around, when off the tractor.
Pros on a 7ft You are going to do a better job of picking up the grass that the tires pushed down.
If you are looking to speed up your mowing time. Instead of backing up for some reason, I just go around in a circle. It is easier on me, the tractor, mower and the grass.
   / 7' Finish Mower #4
Go for it if you have enough HP! (0:
As far as brands... Woods or Land Pride.
   / 7' Finish Mower #6
KB9UDE said:
The Frontier brand I mentioned is also made by Woods.
Oh okay... I recommend Woods, Land Pride, AND Frontier! Lol!
   / 7' Finish Mower #7
I have a 100 inch (8' 4") Rhino FM 100 and it it is really top flight. I pull it behind a TN75 with turf tires and it is really a smooth cut. I have had it for 5 years and had to replace one wheel that wore out the bushing and axle and a strut that lifts the back. I cut about 30 acres per week March through October. It is one tough cookie. Highly recommend. It replaced a 6 foot mower and the difference in time is remarkable.
   / 7' Finish Mower #8
I had an 84" BEFCO RFM which worked great (it came with a tractor I bought). 2nd BEFCO mower I owned and they are very good machines..since now you have Woods, Land Pride, Frontier (which are made by Woods or BEFCO, BTW) and BEFCO.
BTW, if you buy a Frontier (which is what I have now...a 72" RFM), if the front corners are rounded (as is KB9UDE's mower), it's a Woods. If the front corners are squared off, it's a BEFCO.
The only reason I sold the 84" BEFCO was it was too wide for my garage (had about 1/2" clearance per side when I backed into the garage). If it had been a 72" unit, I'd still have it. That in no way is a slam on the Frontier/Woods. That is a great mower too!
   / 7' Finish Mower #10
How big is a 3930 tractor? I have a TC40 tractor on R4 tires which makes it right at 6' wide. I mow with a 6' Befco finish mower. I would like to have a 7' mower so that it will stick out past the tires a little bit. If the mower sticks out past the tires it is a little easier to mow close to walls, fences, etc...
2018 TowMaster T-12D T/A Flatbed Trailer (A55853)
2018 TowMaster...
2011 Ford Explorer SUV (A53424)
2011 Ford Explorer...
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A55852)
2012 Freightliner...
