72D Auto Connect MMM - Spacers and R4s?
   / 72D Auto Connect MMM - Spacers and R4s? #21
The rears are 41". With the non-autoconnect 72" deck, I was able cut at almost 4" high with no issues, but with this deck at full transport height I can get 2". I gotta check out my configuration to see if it is actually going up as high as it can. I also need to check my fluid levels, not sure if they were checked at the dealer as I had them all focused on making it work on the tractor with those wheels?
The front of the deck seems to be a bit low too, so I need to look a that. Seems to me that this should not be an issue with the auto-connect deck.
Have you checked the rear adjustment? There should be 1-2mm max distance from the lift arms to the frame/stop. Of course this is at full lift height.
Nope, and I will do that today.
OK, sorry for the late update - I adjusted the rear connections and now the deck raised to almost 5". Thanks for all the inputs and advice
1977 Ford F-100 Super Cab Pickup Truck (A56858)
1977 Ford F-100...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
LOT: Shop Tools: (2) Sets of Truck Ramps, Pittsburg Creeper, Step Stool, Road Cones, Rolling Stool (A59076)
LOT: Shop Tools...
2015 Nissan Pathfinder 4WD SUV (A56859)
2015 Nissan...
2009 Honda Pilot AWD SUV (A56859)
2009 Honda Pilot...
