750 with a hole in the cylinder
   / 750 with a hole in the cylinder #1
jpt97
John Deere 750
Just purchased a 750 from a client. Has the yanmar 3t80uj motor but a hole in cylinder 1. Before I send the motor off to get sleeved I was wondering if anyone has done a motor swap, for a different engine.
   / 750 with a hole in the cylinder #2
Hard to find info on internet.
I am going look at 750 today. Any issues with that Yanmar engine. The tractor is reviewed as solid.
   / 750 with a hole in the cylinder #3
Yanmar's are good diesel engine's
   / 750 with a hole in the cylinder #4
We bought a 950 new in 79. before it moved on to its next owner a few years ago ot had over 10000 hrs on it. it's still running today, as I see it from time to time with its current owner. They are tuff little tractors!!
   / 750 with a hole in the cylinder #5
They’ll run forever if u change those fuel filters and keep the engine cool..
   / 750 with a hole in the cylinder #6
Yup, those are excellent engines. Fix what needs fixing, and run it, don't change it for something else. I ran a used 650 for 25 years and 1800 hours with zero engine problems. I've run a used JD15 excavator for 22 years, and 2000 hours. I thought I'd had an overheat problem once, and took the head off - everything was perfectly fine. New gaskets, reassembled, and it runs like a charm.
   / 750 with a hole in the cylinder #7
The only thing I’ve run into is the injection pump wearing out due to dirty filters..
Filters are very cheap compared to replacing the inj. pump.!!
Breaking a couple of 20’s 2x a year will usually keep u outta trouble.. unless u run Bio-fuel and let it sit..
   / 750 with a hole in the cylinder #8
Hole in cylinder wall indicates previous tractor owner didn't practice good maintenance of coolant which can cause electrolysis IE cavitation. If I was going to repair this tractors engine I'd bore & sleeve all cylinders.
   / 750 with a hole in the cylinder #9
bio diesel blows
   / 750 with a hole in the cylinder #10
"blows" ???
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A48836)
2006 Volvo VNM...
UNUSED TOPCAT SKID STEER ROTARY CUTTER (A50460)
UNUSED TOPCAT SKID...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
UNUSED CFG EXCAVATOR FLAIL MOWER (A50460)
UNUSED CFG...
2010 Cadillac SRX Luxury SUV (A48082)
2010 Cadillac SRX...
CRAFTSMAN 3500 WATT GAS GENERATOR (A50460)
CRAFTSMAN 3500...
