750 with a hole in the cylinder
   / 750 with a hole in the cylinder #1
jpt97
John Deere 750
Just purchased a 750 from a client. Has the yanmar 3t80uj motor but a hole in cylinder 1. Before I send the motor off to get sleeved I was wondering if anyone has done a motor swap, for a different engine.
   / 750 with a hole in the cylinder #2
Hard to find info on internet.
I am going look at 750 today. Any issues with that Yanmar engine. The tractor is reviewed as solid.
   / 750 with a hole in the cylinder #3
Yanmar's are good diesel engine's
   / 750 with a hole in the cylinder #4
We bought a 950 new in 79. before it moved on to its next owner a few years ago ot had over 10000 hrs on it. it's still running today, as I see it from time to time with its current owner. They are tuff little tractors!!
   / 750 with a hole in the cylinder #5
They’ll run forever if u change those fuel filters and keep the engine cool..
   / 750 with a hole in the cylinder #6
Yup, those are excellent engines. Fix what needs fixing, and run it, don't change it for something else. I ran a used 650 for 25 years and 1800 hours with zero engine problems. I've run a used JD15 excavator for 22 years, and 2000 hours. I thought I'd had an overheat problem once, and took the head off - everything was perfectly fine. New gaskets, reassembled, and it runs like a charm.
   / 750 with a hole in the cylinder #7
The only thing I’ve run into is the injection pump wearing out due to dirty filters..
Filters are very cheap compared to replacing the inj. pump.!!
Breaking a couple of 20’s 2x a year will usually keep u outta trouble.. unless u run Bio-fuel and let it sit..
   / 750 with a hole in the cylinder #8
Hole in cylinder wall indicates previous tractor owner didn't practice good maintenance of coolant which can cause electrolysis IE cavitation. If I was going to repair this tractors engine I'd bore & sleeve all cylinders.
   / 750 with a hole in the cylinder #9
bio diesel blows
   / 750 with a hole in the cylinder #10
"blows" ???
2023 Kubota RTV-XG850 Sidekick (A56435)
2023 Kubota...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
2004 CADILLAC LIMOUSINE (A58018)
2004 CADILLAC...
FRONT MOUNT TANK (A52708)
FRONT MOUNT TANK...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
