755 Not Starting !
   / 755 Not Starting !
Seat switch is working OK.
   / 755 Not Starting ! #12
Battery at 12.50 volts / No power at the starter though.
With your meter, start at one end or the other.
Edit; "No power at the starter" was it before or after your start solenoid ?
Charged battery almost 14 volts now, I do have juice on the large feed wire on the starter. Just nothing on solenoid side. Followed that white wire to the fuel pump shut off solenoid. The fuel pump shut off is not pulling back when the key is turned on or in the start position. It stays when I push it in with my finger.
   / 755 Not Starting ! #14
Sounds like the main start circuit is fine then.
PTO switch ?
Ran a wire down from the battery starter is spin but not engaging
It appears to be the pump shut off selenoid , Power go's in but it will not hold pump open ( to run ) and it won't send the needed power to the starter.
I'm determined to get this thing running tonight. LOL !
Boy do I feel stupid ! I mean I really get the jack *ss of the year award ! This was one big false alarm and very embarrassing to have to admit to my peers. The tractor was chained down on my trailer. One chain went around the loader arm mount under the reverse pedal pushing it backwards slightly knocking out the neutral safety switch in the trans. Sorry for the false alarm guys thanks again for your help. All is well !
2018 Dodge Durango Multipurpose Vehicle (MPV), 175,918 Miles, Third-Row Seating (A56438)
2018 Dodge Durango...
2018 VOLVO EC480EL EXCAVATOR (A60429)
2018 VOLVO EC480EL...
Caterpillar 320 (A60462)
Caterpillar 320...
5th Wheel Hitch (A59230)
5th Wheel Hitch...
iDrive TDS-2010H...
Unused 2025 CFG Industrial MH12R Mini Excavator (A59228)
Unused 2025 CFG...
