790 won't start
   / 790 won't start
If it was a safety switch I wouldn't get any action when turning the key. The tractor is a 2005, the battery was OE. I'll take it to NAPA and have them test it in the morning. However it was a father's day shot with no seat time. What a disappointment.
   / 790 won't start #12
G'day i agree if it was a safety then you would not get any starter engagement at all, you can do a simple load test yourself if you have a volt meter clip it on to the batt terminals and read the voltage before cranking and whilst trying to crank, you should not drop below about 9 volts. You have got me a bit worried when you say that you get no more assistance with the booster batt on it you may have a crook starter i hope not for your sake.
Jon
   / 790 won't start #13
may be a bad starter, or the alternator or regulator also bad the reason it may have went bad as well.
   / 790 won't start
Alright, took the battery to my friendly NAPA store and put it on their tester. It checked out as a good battery even after 2 test cycles. I knew I was then in for some troubleshooting.
The NAPA clerk suggested that I take a good battery back and see if it made a difference; so I did. Put the terminals on and the engine spun like it did when it was new. Went back to the store and signed the charge slip promising to scrape off the appropriate date for warranty. All is well once again.
   / 790 won't start #15
I'm really surprised you old battery would spin the starter when it was jumped. That makes me wonder if the terminals were clean enough (figured you'd already checked that though).
Anyway, glad your 790 starts good now and very glad it wasn't a safety switch.
   / 790 won't start
My first thought was to clean the terminals. Did that and nothing. At least they were clean when I put the new battery in. Thanks everyone for your help and suggestions.
   / 790 won't start #17
Check the ground if you haven't already. I have had problems with that on my 990. I have to go tighten up the bolt every once in a while. When it gets loose sometimes it starts and sometimes it doesn't.
JCB 220XLC-4F EXCAVATOR (A60429)
JCB 220XLC-4F...
2005 Cheverolet 2500 Pick Up Truck (A59814)
2005 Cheverolet...
Quick Attach Adjustable Forks (A59814)
Quick Attach...
2005 GMC C7500 24FT BOX TRUCK (A59904)
2005 GMC C7500...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
