861 diesel problems
   / 861 diesel problems #141
they are good on fuel too!
   / 861 diesel problems #142
Good to hear you got it going without too much trouble. Good luck with it now.
I just fired her up this morning and stepped back to take a quick video with my cell phone as the smoke is clearing away. Later, I ran her for about 30 minutes after I put the blade on the back dragging some leaves out of the yard to the woods. She took a long time before the temperature needle ever stood straight up in the middle of the green. After I shut her down and got off, I noticed the radiator overflow was dribbling. I may have caught a 1/4 cup before it stopped. Looks like I may need a new cap there too, but the fuel cap and fuel sending unit has stopped leaking. Looks like I also have a small oil leak around the #4 fuel injector rubber seal in the block (I reused the old ones). I can't see any other problems though. I got a few other mods and maintenance jobs I have in mind day for this, but for the most part, I'm pleased and ready to kick back and drink a toast. I just wish it was turning spring and not winter, so I can play with it more.
   / 861 diesel problems #145
I tried to open your video but was unable. You may have to set permissions or something.
Try this. I'm new at video posting too.
[video]<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid999.photobucket.com%2Falbums% 2Faf119%2FDalmerM%2F1112140939.mp4&title=">[/video]
Now I got to clean up the mess I've made in my carport cover, barn and tools.
   / 861 diesel problems #147
sounds good.
my 941 D smokes a hair cold and clears up when warm.
   / 861 diesel problems #149
That video link worked. Sounds like an old tiger purring like a kitten to me :thumbsup: Congratulations on a job well done. Maybe now you can put it to work instead of you working on it.
   / 861 diesel problems #151
Thanks for the thread. Nice job. Someday maybe you'll pass it toyour grand kid...that would be cool.
Yes it would be cool to know the grandkids still use my stuff, but I expect my widow will turn my toys into cruise ship vacation fodder:cool2: Heck, she hasn't ever seen the old girl run before or after the rebuild.:confused2: However she has kept a close eye on those parts receipts!:eek:
I was able to install my hydraulic pump gauge I ordered a couple days ago. However the weather has turned bitter cold here in NC for me (low at night 25ish) and I have not tested it out. This may be shorts and tank top weather to you folks up north, but this old southern boy's blood don't move very fast anymore. By the time I got it installed, I wanted to go back inside and get warm. I came out the next day with fresh batteries in my camera to take a couple of pics, hook up my trickle charger, charge the wife's dead battery in her van and quickly headed back inside our house. I even got a heater inside one of the dog houses and both dogs stay snuggled together in there most of the day and night.
   / 861 diesel problems #153
Yeah what's the saying...i hope my wife doen't sell my stuff for what i told her i paid...stay warm down there.
I been wanting to test out the hydraulic gauge I installed, and today it warmed up to the upper 40s this afternoon. I fired the Red Tiger up cold with no block heater and not using the glow/heater plugs, but it took 3 spins of the starter before she caught. Next time I'll use my manifold heaters. I don't have a block heater (yet).
The hydraulic gauge did not move. I raised the lever for the lift and the gauge only registered about 400 lbs. max to lift the 6ft. scrape blade in the air. Once up in the air, it dropped back down to 0 the entire time it was raised. I don't know if those numbers are good or bad, but I'm guessing OK. Worked the tractor dragging leaves off into the woods again long enough for to warm up the engine and parked her again. The new 4 lb. radiator cap I bought did not let any antifreeze dribble out of the overflow this time. The new fuel cap I bought will have to go back for a refund though. It's domed shaped top will not let the hood close all the way. The old one with the homemade leather gasket I made is still holding dry for now, so I'll just wait and see.
I do believe I can call this project done and ready to go. Ill leave the scrape blade on over the winter (unless I find an Indian Summer day to play with something else) just in case I get the chance to move some snow. We usually average one or two good snow falls a year around here that require snow plows on the roads, and that is more than I like, but better than you folks further north and out west have to deal with.
   / 861 diesel problems #155
Sounds like you did an excellent job on the rebuild!
   / 861 diesel problems #156
The system uses an unloader, once lifted, it unloads to about 40 psi. When lifting, pressure is dependent on load, to see meaningful #'s for 3pt pump, chain upper lift arms to axle and exercise lift, have a 3000 or so psi gauge.
   / 861 diesel problems #157
I just read you whole story I to have a 861 Diesel and have just gone through the motor again long story short it runs great I have had it about 6 years, the only thing I have found is it does drip a couple of drops of oil when cold. I did put a high pressure pump in to buy some time with worn bearings but after having the crank machined and new bearings it pins the 80 psi gauge cold and at a very slow idle I run 40 psi. So if I have to add a quart of oil once and a while no big deal.
I'm lucky with mine that all the oil compartments & seals are tight so far - at least no puddles on the concrete. The only oil leak I have is around the rear injector fuel line where the rubber insert sets in the head. Three problems I've noticed with mine since the rebuild is 1) the lift still does a bounce every few seconds when the pressure gauge I installed jumps 20-30 pounds. However when I shut the tractor down with the lift raised with an implement attached, it does not bleed down and let the implement fall.
2) I noticed this winter when I fired it up to move some snow that the overflow on the radiator dribbled a lot of my antifreeze on the ground to the point it began to get hot after about 30 minutes (with snow on the ground) and I had to shut it down to cool off. It has a new thermostat and 4lb radiator cap. Since then I refilled the radiator and opened the cap to the first notch to release the pressure from the system when running. Just this past Wednesday (outside temp about 80 degrees) I attached my box blade and began moving 10 loads of fill dirt we had dumped at our rental house and spent about 3 hours on the tractor. The first time I have really worked it hard since the refurbish and I had no problems with the radiator or temperature. In fact it tended to run cool with the needle on the gauge running at about 11:00 position (about where the orange meets the green on the meter) after the thermostat first opened (at 1:00 position) and the needle moved down it stayed there all the rest of the day.
3) Someone stopped to talk to me about my tractor and I dropped the idle down to hear him better. As I expected the generator light came on. However when he left and I throttled the tractor back up the generator light never went back out and remained glowing strong until I quit. I have not had a chance to check that out yet. By the way I did have to buy a new proper size battery as expected. The small one that was in there died over the winter even with a cheap HF trickle charger attached to it all winter.
By the proof meter I have only added 3 hours to the tractor since my rebuild, but she runs strong so far and seems to have twice the power my little 8N does. I still have a lot of dirt to level and move and a garden to plow in the next few weeks when the rains stop, so it should get a good break in.
The guy that stopped me on my tractor Wed. to talk, is coming by this morning to look at my 8N I have for sale. I had the scoop bucket attached to the 8N and moved about a dozen loads with it Wed. morning to some of the low spots in the yard before the sun ran me back inside till late afternoon shadows when I used the 861D and box blade. I miss the seat that I moved to my 861D. I put the pan seat back on the 8N and I do not like not having a back on the seat. The old 8N still tries to throw me off if I don't have a firm grip on the steering wheel sometimes.
   / 861 diesel problems #159
I just joined this suite and I too have a 861 diesel sounds like you doing a lot of what I have been through I just put a couple of hours on my tractor after having the crank machined and and put new bearings in. I have the complete parts manual and service manual if you need any info . Tony
   / 861 diesel problems #160
put your gen thru a motor test.... does it pass?
403 (A52706)
403 (A52706)
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
(1) UNUSED 31" X 8 MM EXCAVATOR TRACK W/ PIN (A60432)
(1) UNUSED 31" X 8...
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
iDrive TDS-2010H...
