8n not running right. intermittent issue
   / 8n not running right. intermittent issue #31
red tigers are 600/800 series engines
( naa as well as all the series from 55-64 ) 700, 900, 501, 601, 701, 801, 901, 2000-4000 4 cyl.
   / 8n not running right. intermittent issue #32
Have you checked for wobble in the distributor shaft?
Latest update. I went over there today and I think we got it figured out.
We replaced the switch, and did away with the terminal block. The block has a resistor in it. Not sure what it is used for, or if we should have been using it, but it wasn't being used. We were only using the block as a means to connect multiple wires.
The way it "was" wired had the load wire coming off the ammeter, the Genny wire, and a one side of the switch on one terminal. The one not hooked to the resistor. Then one of the resistor studs was used to connect the other side of the switch to the coil and lights.
The way it is wired now, the Genny wire and one side of the switch are hooked to the load terminal of the ammeter. And the other side of the switch goes to the lights and coil still, but without using the terminal block for the connection.
Ran the tractor for a good 20 minutes without missing a beat. Before it would have acted up 5-6 times in that span.
So not sure if the switch was failing, or if one of the studs on the terminal block was grounding out on the back side?? But it works for now.
   / 8n not running right. intermittent issue #34
side mount dizzy don't use resistors
propper wireing for a net reading center 0 ammeter are as follows
bat wire from vreg to one side of ammeter, other side of ammeter to battery stud on solenoid.
wire from vreg side of ammeter to key switch, from there to coil.
wire from vreg side of ammeter to lamp switch, from there to lamps.
IE.. all charge and electrical loads on same side of ammeter. other side of ammeter ONLY has charge to battery.
And yeah.. if your rewire cured it. likely was a bad connection in the wireing.. which is why i reccomend testing with a straight hotwire from bat to coil to sniff out bad connections
In a nutshell, that's how its wired now.
Only difference is the lights are wired after the key, so they can't be left on by mistake.
So one side of ammeter goes straight to bat. Other side is the vreg(Genny) feed, and the switch. Other side of the switch is lights and coil.
Prior to all of this, we could have swore it was a fuel issue. Especially with putting a new wire harness on it when it was rebuilt. But putting a riming light on it like someone else suggested told us it was ignition for sure.
I sure do appreciate everyone's help and patients.
   / 8n not running right. intermittent issue #36
Good stuff. I love it when I fix something on the 8N, fire it up and she runs perfect.
   / 8n not running right. intermittent issue #37
wireing lamps off key leads to key failure.
   / 8n not running right. intermittent issue #38
Yep,
Better to run the headlamps/switching through a relay if operated off the key.
The ignition block isn't designed for the kind of amperage the headlamps draw.
   / 8n not running right. intermittent issue #39
I like to source headlamp power off the same side of the ammeter as the key power and charge lead. this keeps it all net on the meter. correct wire size for addition of lamp load should be figured in too.
   / 8n not running right. intermittent issue #40
Engine overheating!!
Use compressed air and blow out the radiator fins.
Hot engine will cause the fuel to vaporlock.
Donald
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
23105 (A56859)
23105 (A56859)
2010 Ford F-550 4x4 Venturo HT40KX 3 Ton Crane Mechanics Truck (A59230)
2010 Ford F-550...
