9' cultipacker wheel, axle, bearing size
   / 9' cultipacker wheel, axle, bearing size
Now if you had a pinned connection at both ends from the bars that connect your cultipacker axle to a boom pole, down near your drag links and secured from the axle ends to the top of the boom pole with 2 chains you'd have all the degrees of freedom that you need for the implement to move any old which way and still be able to lift it off the ground for transport - provided your 3pt has the lift capacity.
-Jim
If I use a chain for top link wont the top of the cultipacker arm fall into the back of the tractor. most likely 3 pt would be for towing and re locating, atv will probably pull it
   / 9' cultipacker wheel, axle, bearing size #26
I think if you are going to lift it off the ground I would add a center bearing to provide better support, Could not link to your bearing post though.
   / 9' cultipacker wheel, axle, bearing size #27
For those of you interested that picture of the 3 point/tow behind unit came from the Cultipacker Store :thumbsup: OMNI Mfg
   / 9' cultipacker wheel, axle, bearing size #28
I am in the middle of the same type of project. I have old cultipacker that the frame was all bent. I plan on buying from Omni-manu or making a new frame. Someone mentioned there should be some play between the shaft and wheel. I measured the diameter of the wheel holes and they are
1 15/16" and the shaft diameter is about 1 11/16". Is this too much play or just right? With some shaft collars, will this tighten things up nice?
   / 9' cultipacker wheel, axle, bearing size #29
wow they got some stuff, how is there pricing ?
Our used 10 ft Brillion packers are less than half the price they are asking. 10 ft single roller $1095, theirs $2500. Ken Sweet
20ft Bumper Pull Equipment Trailer (A51572)
20ft Bumper Pull...
2011 FREIGHTLINER M2 (A52472)
2011 FREIGHTLINER...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
2010 PETERBILT 340 (A52472)
2010 PETERBILT 340...
5ft 3 Point Hitch Bog Harrow (A51573)
5ft 3 Point Hitch...
