90" finish mower on my b3200
   / 90" finish mower on my b3200 #1
B3200
Erie Pa.
kubota b3200
Do you think my b3200 would have enough power to run a woods 90" rear finish mower, (pull, not lift) Thanks
   / 90" finish mower on my b3200 #2
For the 23 horse power its a long stretch,
and unless you are crawling not much of
an option powerwise in my opinion.
For the money involved you would be better
off buying a pair of towed motorised
"Acre Ease" lawn mowers assuming you intend
on using the belly mower you have-
You will be able to mow wide using the three mowers with trailed hitches
and drop one "Acre Ease" mower; use the two mowers then drop
the other "Acre Ease" and finish mowing with the belly
mower of the B3200 if you want that much width.
I would rather see you buy a six foot finish rotor flail mower from Ken Sweet
one of our fine sponsors in good standing here on the forum.
My father used a John Deere 7 foot finish rotor flail mower on a Ford Jubilee using three rows of grass slicer knives
   / 90" finish mower on my b3200 #3
I used a Landpride 72" RFM on my B7800 and the B3200 and it done fine operating and lifting. Check the difference in weight between woods 90 and Landpride 72. I believe it will do it.
   / 90" finish mower on my b3200 #5
I can't say how well your B3200 will work with a 90" RFM, but I will suggest you determine where you'll leave this big mower before you spend the money.
My RFM is a 7' Befco (actually 86" wide) and it is wide!!! When I back into my garage, there's maybe an inch (or less) clearance on either side...tight fit. It won't fit my outbuilding so I've got to leave it outside (under a trap) for the winter.
I wouldn't buy a mower this size...it came with the tractor I bought earlier this year (2010).
So, make sure you have a place to leave that big mower!
I thought it might be pushing it a bit, I now have about 12 acres to mow, i didn't know that when I bought the b3200, some I will brush hog 1 or 2 times a year, some I will finish mow weekly. Wishlist would be something like a L 5240 with a 12 ft. batwing, but I'm building a log home on this land and need to finish the house first before other wishes come true.
   / 90" finish mower on my b3200 #7
Go for it. My B3030 handles a 60" MMM like it isn't even there. Another 30" will hardly make a difference.
Nice looking land and home you have. How much different does it look since Oct. of '09? Good luck.
Photos are from october of 2010, so not much different just a lot more snow.
   / 90" finish mower on my b3200 #9
I have the woods 990 and pulled it with a L3130 before I got my L4240. The L4240 had to go in for some warranty work and I hooked the woods up to my B7800 just to see if it could handle it. Well it done good on flat land, the temp did run up a little. I did not try it on the hills because I new it would pull it sideways. The 990 is real heavy and when its a little wet it has moved the 3130 side ways some. The 990 is a great mower and for as big it is, it doesn't take a lot of HP to turn it, but pulling up a hill I think it would pull the tractor down way to much and side ways it would be unsafe.
   / 90" finish mower on my b3200 #10
I have had three RM-990's (still have 2) and I can say 23 hp isn't power enough to do a good job. I had one on a L345DT years back and if the crop was dense, or wet or the ground was sloped, the tractor was over-matched by the mower. I liked the 990 enough that I got a bigger tractor. The 990 is a great mower but it needs at least 34 pto horsepower. You can get by with less, but it will often feel under powered. If you are planning on a bigger tractor within a year or two then you could live with it for a while - but it will give you an itch. My 2 cents Take care, Dick B (97 1/2 ton Z71 chev, 01 vette 6-spd)
2008 International School Bus Hood | OEM Quality Replacement | Fits IC Bus and More (A46877)
2008 International...
2015 GMC Sierra 3500 4x4 Truck (Diesel), VIN # 1GT424E8XFF644967 (A44391)
2015 GMC Sierra...
Ryobi Expanded Capacity Table Saw with Rolling Stand (A44391)
Ryobi Expanded...
2000 GMC C6500 FLATBED TRUCK (A43003)
2000 GMC C6500...
2007 Thomas School Bus  Freightliner Chassis, MBE-900 Diesel (Non-Running) (A46877)
2007 Thomas School...
2018 Ford F-550 Truck, VIN # 1FDUF5GTXJEC35552 (A44391)
2018 Ford F-550...
