914MMM Trick
   / 914MMM Trick #1
thcri
Elite Member
Minnesota SE
New Holland TC29D, 2001
When mowing in taller grass my 914MMM would leave windrows off the side of the chute about 2 feet out. I got myself two really thick flat washers and laid them on each end of the spring plate to lift the chute up some. Man did it make a difference. It was throwing grass out 7 feet. No windrows. I think I will make the washers permanent. But I caution you all as I am sure there is some safety issues there with the chute pointed down some. the washers were about and 1/8" thick each
Murph
   / 914MMM Trick #2
Murph.........I'll probably get some greif over this..........but the chute for my 914 6' MMM is lying in my shop under the workbench.........Adding the washers there probably won't make a difference but I could try.............TOM
   / 914MMM Trick #3
Murph,
How did you get those washers to stay in place? My chute bounces so much, they would fall out in a matter of seconds!
   / 914MMM Trick
The heaby spring on my chute keeps mine tight. I have no problems keeping them there. I think a person could put some clear caulk on the bottom side of the washers and then it could bounce all it wants. If you need to remove them you would still be able to. Just a thought.
murph
   / 914MMM Trick #5
Heck, I'm not sure where I put my chute. I took it off before I ever mowed. /forums/images/graemlins/blush.gif
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2022 Horizon Trailer (A55973)
2022 Horizon...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
AEREATOR (A58214)
AEREATOR (A58214)
2016 Ford F-150 XLT Pickup Truck, VIN: 1FTEX1EP4GFD61185, Extended Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2016 Ford F-150...
