94 Ford F250 battery cable
   / 94 Ford F250 battery cable #61
I had a similar starter experience coming from the opposite end of things.
The alternator on the '99 died and the aux. battery (driver side) finally
went bad and ruined the main battery (pass side) I guess. While taking
this all apart, I broke one of the positive terminals. I decided to get all
new cables, batteries, and of course the alternator. I put it all back
together and hit the key. Started like a brand new truck.
Same starter as before just getting good connection and ground...
Just wanted to report that this all turned out OK. I went ahead and pulled the starter, took it to the bench and put the solenoid back on and reinstalled. The top bolt was somewhat difficult, but not too bad. Put her back together and.....CLICK.
Charged the batteries very slowly for 4 days, and......CLICK. Replaced the batteries and.....CLICK.
Pulled the starter AGAIN and bench tested it with some jumper cables.... CLICK.
Took the solenoid back off and put it back together, this time very carefully making sure the spring was seated properly. Bench tested - BINGO! Reinstalled on the truck and it started fine.....
I was then able to fix the original problem, which was that the something was draining the batteries. Disconnected both grounds and put a test light between one ground wire and the negative post on a battery. Sure enough it lit up. Pulled the red wire off the alternator...no change. Pull the positve cable off the starter relay - light goes out.
I went to the parts store and picked up a new starter relay for $10 and replaced it. Light still burns! Duh, there are 3 more wires connected to it, so could have something to do with those. Sure enough one of them, when disconnected made the light go off. This one disappears into a huge wiring harness.
Started pulling fuses one at at time. Pull all of them, then realize the driver's door is open (and so is the dome light, drawing current). Close the door and pull them all again, but the light stays on. Hmm.....
Then I remember the old CD changer a previous owner had mounted to the back of the cab, never has worked. Took some brackets off to remove the changer and found the cable where it plugged in, pulled it lose.....LIGHT OUT!
Can't believe is has been that blamed CD changer all this time! That thing is in the garbage, unfortunately the control head was epoxied to the dash and I can't get it off. But it is no longer sucking current and the batteries should hopefully now be fine.
   / 94 Ford F250 battery cable #63
Alan, what a great story of stick-to-it-iveness! Your persistence and troubleshooting logic paid off. You must have been really frustrated at times, but kept plugging along. Great job.:)
   / 94 Ford F250 battery cable #64
Good to hear you found the problem! Tracing electrical problems is such a headache some times...
Just as a followup, after sitting a week my truck fired right up and I went and got a load of firewood on Saturday. Nice to have it back.
2015 DODGE RAM...
2021 Simex padding bucket, 8-9 ton class, like new (A52384)
2021 Simex padding...
RYOBI EASY START INVERTER GENERATOR (A51248)
RYOBI EASY START...
2025 Safety Basket Forklift Attachment (A51691)
2025 Safety Basket...
2005 Ford Taurus SE Sedan (A51694)
2005 Ford Taurus...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
