Gittyup
Elite Member
- Joined
- Oct 4, 2007
- Messages
- 3,145
- Location
- Mid Atlantic
- Tractor
- Kioti CK25 Shuttle Shift, loaded tires, JD X739
Well guys a very disappointing day so far. The ignition module came in which includes the key switch and board I hooked it all up as the other was and the tractor started 6-7 times but as I started the tractor each time I could hear the solenoid trying to stay engaged and then it would release. Finally it went back to the old way of trying to start when the key is in the run position. I guess I will try to figure this thing out one way or another. Is there a way to bench test the starter with a 12 volt battery? If the solenoid is the problem then it should do it then correct? I will double check all the wiring and see if something has gotten mashed or messed up when I had it on the workbench fixing the cam. I priced a new starter not cheap at all.
I don't see how a starter would try to keep running by itself, as it shouldn't have any power when the key is released back to run position. I suspect something happened taking the motor in and out. Maybe there is a short somewhere continuing to provide power to it (sometimes).
