A couple of "strange" towing/tie down questions
   / A couple of "strange" towing/tie down questions #11
The superduty tow rings would be fine for a tractor the size of yours. Be aware, the rings you speak of have a small ID, and many chain hooks will not fit thru them, making the chain-down process more difficult in your situation. But a good idea none the less, one i will save, as I have several superdutys, one which is getting parted out! Will save thoes tow rings!
Also agree about the trailer capacity comments... gross trailer rating, vs actual load weight, you don't want to have it loaded to max every time you use it. If the normal load you intend to carry is more than 75-80% of the payload ability of the trailer, get bigger trailer. (10k gross trailer - 2500lb trailer wgt = 7500lb payload × 80% = > normal load. Arbitrary trailer weight numbers, but that's the formula I use.)
The tow vehicle plays a big part in trailer safety as well... what's pulling this new trailer?
   / A couple of "strange" towing/tie down questions #12
Straps work well as long as they are not wrapped around or able to chafe on the items they are holding down.
That's why the OP showed axle straps which have a extra layer on them to protect the part of the strap that takes the load from abrasion.
I think that the wheel straps will work well for the front, but they may not be big enough for the back.
Aaron Z
   / A couple of "strange" towing/tie down questions #13
OP, others have mentioned trailer weight; I'll mention length...
I have a similar size NH TC40D. I have had need to have both FEL and 6' rotary mower. I had to set the mower in the bed of the truck because the load would have been too long.
I measured my tractor with the loader and rotary mower, from the edge of the bucket to the end of the tail-wheel on the mower. 24'.....
It is something to consider. I hardly ever take the loader off. And, I always have something on the 3pt; mower, scraper, chipper etc.
I have my existing trailer that I got when I had a smaller Kubota B series. It was perfect then, but this New Holland is much bigger. I can't afford a bigger trailer right now, so have to make do with putting implements in the truck, or trailering them seperately in my utility trailer. Both are a pain in butt...
   / A couple of "strange" towing/tie down questions #14
Couldn't a mower hang over the tail of the trailer a bit?
I carry my medium size TLB with the hoe extending about 2' beyond the tail of my 20' trailer, and I set my loader bucket, edge down, and curled onto the front trailer edge.
I use a clean red flag on the rear, about 4' above the hoe bucket.
I ordered my 14K trailer with 20' deck, so that I can store another vehicle ahead of it in my building, though I would have preferred a 24' trailer.
My trailer is strictly for ME,(no business use, never for hire) and is used only very occasionally.
I do not have an answer for your tie down question.
I DO have a suggestion about the trailer you are planning to buy.
Your tractor at 3574 lbs., plus an estimated empty trailer weight of 3400 lbs. (I have a 20' equipment trailer) will gross out at approximately 6974 lbs.
You are planning to buy a trailer with two 3500 lb. axles, for a projected load that is only 26 lbs. under GVWR maximum?
Will you ever put any additional weight on the trailer?
Adding anything else, other than a big bag of feathers, will exceed the GVWR of your trailer.
You absolutely should buy a 10,000 lb. GVWR trailer (two 5000 lb. axles).
You should also consider getting as many "D" ring tie downs as is reasonably possible.
Stake pockets should be plentiful, and a rub rail is essential.
Spring type axles (cheaper) may be better in Florida, as torsion axle rubber will possibly deteriorate over time in the Florida heat.
Do get 16" wheels!
Unless you have a "dually" or some other heavy duty vehicle, you should strongly consider a weight distribution/sway control hitch. I find the "Equal-i-zer" brand to be the best for both of those functions.
I frequently read here of folks needing to pay hefty amounts to a dealer for tractor repair transportation.
While buying a trailer for tractor repair purposes would not be cost effective, I find that having a 20' equipment trailer, for other uses, is very convenient.
In most cases, a well kept used trailer can be resold, if necessary, for almost the same price as the original cost.
I would recommend AGAINST buying a used trailer however. Many (if not most) are in neglected/unsafe condition.
If you want to custom order a trailer I have heard that Kaufmanntrailers.com is very good company to deal with, and they will ship anywhere in the USA. My trailer is not from Kaufmann, but in the future I would likely buy from them. Kaufmann pricing seems to be excellent also.
HAPPY TRAILER 2018 HUNTING !!
Thanks for the info. The trailer has an empty weight of 2200 lbs. It is not a heavy duty trailer, nor was it designed or intended to be bought as an equipment trailer. I will have 1200lbs of leeway, which will be more than enough, I think. I figure if I ever am hauling my tractor on a regular basis, I will invest in a more substantial trailer, but right now cost is as much of a concern as capability. I am mainly buying the trailer as an extended truck bed, to allow me to haul long lumber, poles, roofing material, etc. for small projects that will not fit in my truck bed. I hope I won't ever have to haul my tractor anywhere, but if I do on the odd occasion, this trailer should be sufficient.
I'm not sure why I kept them, but I had a brush guard on the truck they came off. At that time, I think I had a tendency to rob anything of value from a truck when I traded it, so the tow hooks were very easy to remove and keep. 16 years later, they MAY come in handy. If I wind up using them, I will post up some pictures in the Build It Yourself section.
Definitely something to consider, but again, I hope to never have to trailer this thing anywhere. If anything, it will be going to the dealer in the catastrophic situation that I can't repair something, hopefully long into the future. I certainly will not be towing it with any 3pt attachments.
Aaron Z
Exactly, the axle straps have an extra layer of abrasion-resistant material on the outside of them, so I'm not too concerned about that situation. That's why I would prefer using the straps in conjunction with other straps or chains as well, just in case abrasion became a problem.
   / A couple of "strange" towing/tie down questions #19
You will definitely enjoy having a 20' trailer!
I am surprised that the 7000 GVWR 20' trailer only weighs 2200 lbs.
I have a 16' 7000 GVWR cargo trailer (3/4" plywood deck) that weighs 2100 lbs., and it is only 16' long.
That 2200lb figure is from the dealer/mfg. It is essentially a glorified flatbed utility trailer without the upright rails, like a typical utility/landscape trailer. Pretty light duty, but I am looking for something to carry long items, plus I have a new truck with a bed cover on it that I am pretty much treating like a trunk instead if a truck bed. Trying to find a nice middle ground of a trailer that will not break the bank but will generally do everything I reasonably need it to do. In general, if I want to haul off yard debris, scrap metal, or bring in lumber, concrete, or other items that I would have just thrown in the bed of my old truck, I am going to hook up my trailer for those jobs. Again, fairly uncommon tasks so it won't be too terribly unwieldy to do it this way "I hope".
Ford Super Duty Pickup Truck Bed (A55973)
Ford Super Duty...
2019 Freightliner M2 106 AWD Terex Hi-Ranger TC55 55ft Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
Rolling Steel Hoist w/Chainfall, 9' W x 12'H (A59076)
Rolling Steel...
2004 PROCO 130BBL VACUUM (A58214)
2004 PROCO 130BBL...
2016 Chevrolet Express Shuttle Bus (A56858)
2016 Chevrolet...
