A GOOD SMALL SQUARE BALER?
   / A GOOD SMALL SQUARE BALER? #11
zzvyb6 said:
Not sure where this "fact" comes from. Bale density is set by the bale compressor tension: Just add some crank to the turn handles. Then you adjust bale length with the measuring wheel pin to get a bale length compatible with your elevator, stack wagon, thrower, kicker, wagon helper. and customer. The 14T goes 1 stroke per second at 540 input rpm. For the 13 flakes per bale that are considered "law" here in Michigan, you should get 40 - 50 lb bales. Last week I forgot to reset the tension after deciding to go for one more cutting. I have 150# bales that my customers hate to handle in spite of the tonnage bargain. There's 3 times as many flakes. That's tight !!
Other balers run 80 - 90 strokes per minute. So what: the number of charges which deliver the pre-set bale length is all that matters. These balers cause horse starvation because owners feed "2 flakes" at a time. In a 14T the flakes are 3" thick. In a 336 the flakes are 1" thick.
Be kind to animals: Read the manual and do the math. Run the machine at rated rpm, charge rate (windrow volume), bale tension and length.
Don't blame the machinery if your bales are light,fluffy, and twinkie shaped.
To each his own-in a production setting give me a 348 or MF 1839 anyday. I do not dispute that you can crank down the Bale Tension (but there is a reason for the uptick in strokes per minute in the Bale Chamber)-the challenge is to keep up the ground speed and get 'er done (a Model T can get you there-a Cadillac DTS will get you there faster and in luxury)-
   / A GOOD SMALL SQUARE BALER? #12
I use an IH 37 on my BX1500. Ok for reasonably tight bales. We dont like them too tight so that excess moisture is not trapped. Our 30HP tractor has plenty of power to do anything the baler is capable of on any terrain. The 70HP is total overkill and I only ever use it for the weight when pulling the hay wagon behind the baler. Based on what Im hearing about other balers here I would recommend the IH if you can find one in good condition.
larry
   / A GOOD SMALL SQUARE BALER? #13
(Rant) (with a smile on my face!)
Sorry to have this tone, this is my Grandfather and my Dad coming out in me here...:eek: But... (and really I'm not mad here:)... this is just the lecture that I would get if I would have said something like that above ;) :))
Man, there must be a bunch of city farmers on here!!! I read stories on this website of guys trying to drag a disk across a field in road gear (or just 1 or 2 under it), wondering why the tractor is bogging down and making this huge ridge... guys wanting to go as fast as possible with a square baler... etc.
The challenge is NOT to keep the groundspeed up and get 'er done... any clod can do that.
The CHALLENGE is to use the proper groundspeed for the equipment that you have to work with and get the job done RIGHT.
Any fool can pull a baler down the windrow, crowding it as much as he can, keeping the groundspeed up. But, what does that get you besides done faster? Busted shear bolts, no two bales the same length, busted U-joints. Did I mention that the bales won't all be the same length? I'll let you figure out why that is... ;)
It's a good thing there aren't that many old timer's on this website... there'd be a good butt chewin' going on every day about something that someone has tried to do!!! :D:D:D
(/Rant)
ON the original question... I've only operated and been behind John Deere 14T's and 24T's all my life. We had a 24T that we always pulled with ample hp, and my Great Uncle had a 24T also that he pulled mostly with a JD 60. That baler would make the ol' 60 snort pretty good in heavy windrows. My Bro' in law has a JD 14T that they pull with a MF235, and obviously it handles it with no problems. Your Kubota might run a 14 T in light to moderate windrows, but if the hay is heavy (like first and 2nd cutting here in Illinois), you might not have enough poop to keep things going... and either way, you'll be pulling the baler only, and picking up the bales off the ground. I dont' think you've got the weight and horsepower to pull the baler and a wagon full of bales all at the same time. You can keep the windrows light(er) by not double raking (combining 2 windrows from the mower into 1) so that would help too. A baler is a heavy piece of equipment (heavier than it looks), and if you're on anything other than flat ground, I think I'd err on the side of safety and get a bigger tractor to run the baler... It's not so much "can the tractor pull it", as it is, "can the tractor STOP it". That's how you have to approach this problem. I think your tractor will run a baler, but it will be quite marginal at the very best... it's just too small.
   / A GOOD SMALL SQUARE BALER? #14
My 14T is still working well after 40 years. Keep the knife sharp, springs at tension, plunger stop free of debris, plastic twine, double windrow, drop on the ground; quarter turn or handoff to a towed wagon, walking ground speed, 35 hp.
What's the problem? (Pic baler_II was taken on the fly).
   / A GOOD SMALL SQUARE BALER? #15
I baled for 20 years with a New Holland 273. Small relative to many balers, and not at all demanding as far as hp/weight of tractor to run it. You'll never hear me say anything bad about a 273.
I bought a used John Deere 336 at an estate auction. (10 years ago?) I planned on trying to sell it for a decent profit. I used it one time and promptly sold the New Holland. Still have the Deere. I usually bale with my 150 Massey. (turned up to 47 pto hp) I REALLY heavy hay, it'll bounce me around if I try to feed it too fast. A good sign to slow up a tad bit. For my money, the 336 Deere is about as good as a baler needs to be.
I was talking with my neighbor and he's a big JD man and he suggested a 330 jd, said he thought it made like a 4 x 4 bale and only needed about a 30 hp tractor. Anyone had any experience with these machines?
   / A GOOD SMALL SQUARE BALER? #17
MANUFACTURER
MODEL John Deere
328
Baler Design
Bale Size
Height x Width, in. (cm) 14x18 (36x46)
Length, in. (cm) 12 to 50 (30.5 to 127)
Maximum Volume, cu. ft. (m3) ---
Dry Bale Weight, lb. (kg) N/A
Pickup
Pickup Width, in. (cm) 74 (187.9)
Tooth Bars/Teeth 4 bars, 104 teeth
Lift Control Crank (hydraulic opt.)
Pickup Diameter, in. (cm) 19.5 (49.5)
Auger
Diameter, in. (cm) 16 (41)
Length, in. (cm) 61 (154.9)
Plunger
Strokes/Minute 80
Stroke Length, in. (cm) 30 (76.2)
Typing Mechanism
No. of Knotters 2
Twine Capacity 4
Twine Type Plastic or sisal
Knot Strength (Minimum Required) ---
Central Lube System Optional
Wire Twisters ---
Wire Ball Capacity N/A
Baler Dimensions
Length w/short tongue, in. (cm) ---
Length w/long tongue, in. (cm) 227 (576.5)
Width, ft.-in. (cm) 108 (274.3)
Height, ft.-in. (cm) 67 (170.2)
Weight, lb. (kg) Empty 2685 (1208)
Tractor Requirements
PTO Speed, rpm 540
Minimum PTO, hp 35 <<<Personally I'd recommend quite a bit more HP with a Thrower and a Hay Wagon is trailing behind with serveral hundred bales in it...:D
Drive Mechanism
Driveline Equal angle 3 joint category 4
Optional Driveline NA
Pickup Belt
Plunger Gear and shaft
Knotters Gear and shaft
Feeder Forks Gear and shaft
Size of Flywheel, lb. (kg) 227 (103)
Drive Train Protection
PTO Slip clutch & overrunning clutch
Gearbox Disk slip clutch & shear bolt
Pickup Belt slip
Needles Shear bolt/plunger head stop
Knotters Shear bolt
Tires
RH Standard tire size 26x12.0-12, 4 ply
RH Optional tire size ---
LH Standard tire size 11L-14, 6 ply
LH Optional tire size ---
Gauge Wheels 1 optional
Pickup Gauge Wheels Tires Size 16.5x6.50-8
Lights
Work None
Transport lights None
Density Control System
Adjustable Bale Density Mechanical crank
Adjustable Hydraulic Bale Density Optional
Bale Counter ---
Bale Ejector
Available Optional
Bale Chute
Short chute Optional
Long chute Optional
Side bale drop chute Optional
Wagon hitch Optional
   / A GOOD SMALL SQUARE BALER? #18
HPXDEEREDEALER said:
Im a john deere dealer so i shouldnt say this... But Hesston makes the best square baler out there. I'm not sure the model for the smaller one but if you have dealer thats the one to get.
Actually Hesston doesn't even advertise a smaller baler on its website anymore only the BIG baler...The AGCO conglomerate pushes MF or Challenger small balers...
JD328 has the same knotter that the original JD Balers had...still works great...and in terms of a Thrower...the JD pan thrower can't be beat...especially when you are baling on the heavier side of bale weight
   / A GOOD SMALL SQUARE BALER? #19
Hi Guys
I'm going to throw in my two cents worth here and please correct me if I'm wrong. In my experience as a mechanic and having to fix all aspects of farm machinery, as well as being the son of a dairy farmer. I have been taught by all that I have dealt with that when baling, there is an old adage: -
Take the hay to the baler and not the baler to the hay. In other words, make the rows bigger and drive the machine slower (ground speed). This keeps an even load on the drive line of the tractor and the baler, keeps a uniform amount of crop going into the baler and hence maintains density exactly where you set it.
Having worked around and on small, round and large squares in both hay and silage, this seems to be the best way to get the best capacity out of your units.
I have had some experience with the Hesston "B" line in Massey guise years ago and this is a very good baler, but it does like horsepower in front of it to maintain capacity. Reliability wise though it is excellent.
Please advise if anyone disagrees as it is always good to get other ideas.
   / A GOOD SMALL SQUARE BALER? #20
My experience is make the windrow the right size and err on the smaller side. Our hay is long and stemmy so it can pull in gulps that are too big in big windrows which is hard on rigging.
Consistant windrows = consistant bales
2020 Deere 325G (A50123)
2020 Deere 325G...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
2016 Isuzu NRR Trash Truck, VIN # JALE5W162G7300782 (A54865)
2016 Isuzu NRR...
2004 IC Corporation 3000IC School Bus (A55852)
2004 IC...
CASE 40XT SKID STEER (A52707)
CASE 40XT SKID...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A55851)
2015 Kubota...
