A little bit more technical advice please
   / A little bit more technical advice please #71
The gasket usually comes with the dust cap. If you look on ebay you can get all of these items, and many more they are made in china, turkey or what not but the ones from the dealer probably are to. The only thing I really would advise getting from the dealer would be the points. I have got some bad sets of points even from TSC. I really have no idea where the ones from the dealer are made but I would think they would be better or at least they should be.
I like to shop for my (old ford) parts on ebay because my dealer is so far away and if I buy all of my items from the same store and combine shipping they come direct to my door. I guess I am lazy or is it because I get more beer drinking time that way!:thumbsup:
   / A little bit more technical advice please #72
'even' from tsc?
really?
it's well know TSC points are about the junkies crappiest you can buy. they are horrid tisco points.
soft plastic rubbing blocks. pooly formed stampings with holes in the wrong spot. there is seemingly no hard coating on the breaker surface..a dn they corode if you stare at them for 2 minutes.. or, if not stareing.. they corode on their own as soon as you look away... theor springs and insulation grommet at the pivots are junk and most of the time the breakers don't strike square. for a 4$ set of points.. they cost about 3.75$ too much.
best bet are standard ignition / blue strak / BW
premium pierced / ventilated echlin are nice as well.
expect to pay up to 18$ for a premium set that can last a decade or more if cleaned with paper..e tc. I havn't repalced a set of quality points in years. i clean a few now and then.. and I changes any tisco that come to me asap.
did i mention tisco points are worse that anything 'lucas prince of darkness' ever dreamed up ?
I have the dust cap guesseral, just no gasket under it. I recently got the tractor the way it is and I am slowly going through the all the routine maintenance and any other issues that come up with the help from the fellow members on here, and what's covered in my manual. Soundguy thanks for the info on the points. I know I asked you about the gen. Just for advance info and bouncing thoughts around in my head... what does the gen/alt swap involve?
   / A little bit more technical advice please #74
the swap involves buying or making the correct brackets. minor change to the wire harness, buying the alt.. and perhaps a belt and pulley change, plus addition of a diode, resistor or lamp into the wire harness, maybee, depending on setup... if going from 6 to 12v.. then you need a new battery.. need to remove the old vreg. need a new coil and lamps...
if you have a working genny.. I'd keep it.
Hey soundman, I caught one of your threads on another site while looking for info and just wanted to check a couple part numbers with ya.
Points # cd8081x
Condensor # fd75x
Dis. Cap # fd128
Rotor # fd108
These are all good numbers for the standard igniton parts...? Need to take a second look, but I may need a breaker plate too. Do you have a p/n for one of those by chance? Thanks soundguy.
   / A little bit more technical advice please #76
front and sidemount ignition info:
no need for a breaker palte # it's either a front or side mount. impossible to swap the 2.. so just order by type. YTMAG has them.. ps your #'s apepar to be for sidemount..e tc..
Ford 9-2-8n Front mount distribuitor ignition service:
gap points to .015
Front Mount distributor...
NAPA #CS35
Standard Ignition Blue Streak #FD-6769X (Premium)
Condensor:
NAPA #FA200
Standard Ignition #FD-71
Rotor:
NAPA #FA300
Standard Ignition #FD-104
Distributor Cap:
NAPA #FA350
Standard Ignition #FD-126
Side-Mount Distributor: 8n thru 4 cyl thousand series
gap points to .025
NAPA #CS749
NAPA HEAVY DUTY PIERCED (ventilated) #CS753
Standard Ignition #FD-8081
Standard Ignition Blue Streak #FD-8081X (Premium)
Condensor:
NAPA #FA66
Standard Ignition #FD-75
Standard Ignition Blue Streak #FD75X (Premium)
Rotor:
NAPA #FA67
Standard Ignition #FD-108
Distributor Cap:
NAPA #FA352
Standard Ignition #FD-128
side mount points hold down screws #8-32 X 3/16
FORD AUTOMOBILE dealer parts counter. come with built-in lockwasher. p/n 355047-S7 (#8-32 X 0.19)
I need a little help here... I have been trying to figure the electrical and wiring on this 4000. Here is what I know. It has a 12v battery. The neg is to ground. It has a generator. With ignition switch turned on coil meters almost 12v. Voltage regulator on the steering column has 6v stamped on it. As I read the schematics in the back of the I&T manual, wires & colors seem to follow both diagrams...? The 12v diagram seems to be closer, but the 6v diagram shows the coil and distributor that follow also. Is there any identifying facts features? Or do I have some kind of mix up 6v system with a 12v battery like soundguy mentioned. If so what is the best way to get this figured out? Thanks for any help.
   / A little bit more technical advice please #78
sound slike a 6v reg.. 6v gen.. and a 12v battery.
that's the common 'moron' conversion to 12v that someone stuck you with.
   / A little bit more technical advice please #79
Hay be nice now! That's how Dad did it for years when we were farming! Of course I really don't think he had the money to do it any other way!
   / A little bit more technical advice please #80
it's one thing when you ( your family that's using the tractor ) does it.
it's another when you sell it to someone jiggered up like that.. and then leave them in the dark about it.
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
DUMP HOPPER (A53843)
SDLANCH ELECTRIC GOLF CART (A53843)
SDLANCH ELECTRIC...
2012 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2012 Ford F-350...
