Oil & Fuel A quick 5 gallon fuel container rant
   / A quick 5 gallon fuel container rant #91
Builder said:
Yep, I did it on my tractors, too. Really comes in handy. My Case came with 2 of them from the factory, but they're in the cab in a bad spot for the pump. I think i'll wire a 2 pin flat from the battery box or some kind of weatherproof 12V socket. Trouble is, i can't find any that are truly weatherprrof & rugged.
Have you found one with a good sealing rubber cap?
Try Marine supply. I mounted one on my dash, and it has been sealed fine.
   / A quick 5 gallon fuel container rant #92
   / A quick 5 gallon fuel container rant #93
I (under attack of frustration) just bought 12 V fuel transfer pump in local farm supply. Then I installed a 4 contact trailer receptacle on the back of the tractor. One contact is 12 V common connected to minus terminal on the battery, one contact is connected to plus 12 V on the battery in series with 20A automatic breaker and one contact is connected also to the breaker but with a switch in series. That one is used for control of a three point sprayer. Since the transfer pump has its own switch it has a plug wired to direct 12 V. The sprayer has a plug wired to switched 12 V. Now I need to acquire about 50 gallon tank but so far couldn't find one for reasonable amount of money.
   / A quick 5 gallon fuel container rant #94
*Now I need to acquire a tank that will hold about 50 gallons but so far can't find one for a reasonable amount of money.
Click on picture for a larger more deatiled view.
*You don't need to pay $100 or more for a 50 gallon tank that won't work anyway because it don't have the right openings to use a pump on.
I paid 12 bucks for this 30 gallon one.
I recently bought 2 55 gallon ones for 12 dollars a piece.
A couple of months before that I bought a 55 gallon one for $17.oo.
   / A quick 5 gallon fuel container rant #95
Prices in south central Oklahoma are lower for drums. I pay from free to about $10 for 50 gal polly drums or steel. I have at least a dozen in reserve.
Pat
   / A quick 5 gallon fuel container rant #96
Pat
I have 11 30 Gal plastic
3 55 gal plastic
6 55 gal steel.
   / A quick 5 gallon fuel container rant #97
Since this is around post # 97, can we change the title? Its no longer a "quick" 5 gallon fuel container rant!
   / A quick 5 gallon fuel container rant #99
I have several of the old "Fire Proof" metal gas cans with the spring loaded lid over the spout. I just painted a couple of them yellow and they work well.
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A53472)
2000 Kenworth W900...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A52576)
2020 CHEVROLET...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
2003 International 4300 Dump Truck, VIN # 1HTMMAAL83H562953 (A51572)
2003 International...
