? about GC2310 and depth of york rake
   / ? about GC2310 and depth of york rake #1
ad11ad
I purchased a york rake when I bought my tractor and didnt ask how to hook it up and use. I follwed the directions and I believe it is hooked up correct. But when I lower it using the control it goes down but not not as deep into the ground as I would like it to. Is their another adjustment that will make it go down further? Thanks
   / ? about GC2310 and depth of york rake #3
ad11ad, Hi mate, I have a new 2310 too.I am building a landscape rake . Much imformation I found in the build it yourself section, Maybe you could ask your question in the attachments section, it is agood question I love my little TLB, I named it Harry.I love my cats too.
   / ? about GC2310 and depth of york rake #4
   / ? about GC2310 and depth of york rake #5
I am not sure how your 3 point looks... Do you have extra holes to make your arms go down farther?
Attached is a pic of my 1533, I marked the spot where the extra holes I am talking about. So if I wanted my 3pt to go down farther I would use the holes closer to the tractor.
   / ? about GC2310 and depth of york rake #6
   / ? about GC2310 and depth of york rake #7
MrSteve, I looked at the 2310 lift arms and they only have one set of holes, I suppose you could drill two more inboard ones. My question to ad11ad is, why are you trying to lower the rake below grade, I thought the rake was held at grade to level and collect debris.Perhaps a box blade would be used with scarifers to loosen objects. Many have said that gauge wheels on a rake are the cats meow, they keep the rake from digging in,alowing you to level the surface.
   / ? about GC2310 and depth of york rake #8
I was trying to pull some roots on a area I just cleared and the rake was only going an inch or 2 into the ground and the roots would just slid out. But I made some adjustments and it is working better. I do have a wheel but it is a single wheel and it works ok but not sure it was work the extra money. A friend as a two wheels on the outside of the rake and I like the was his works much better.
2015 DODGE RAM...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2021 CATERPILLAR 279D3 SKID STEER (A51242)
2021 CATERPILLAR...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52128)
2012 Freightliner...
