? about GC2310 and depth of york rake
   / ? about GC2310 and depth of york rake #1
ad11ad
I purchased a york rake when I bought my tractor and didnt ask how to hook it up and use. I follwed the directions and I believe it is hooked up correct. But when I lower it using the control it goes down but not not as deep into the ground as I would like it to. Is their another adjustment that will make it go down further? Thanks
   / ? about GC2310 and depth of york rake #3
ad11ad, Hi mate, I have a new 2310 too.I am building a landscape rake . Much imformation I found in the build it yourself section, Maybe you could ask your question in the attachments section, it is agood question I love my little TLB, I named it Harry.I love my cats too.
   / ? about GC2310 and depth of york rake #4
   / ? about GC2310 and depth of york rake #5
I am not sure how your 3 point looks... Do you have extra holes to make your arms go down farther?
Attached is a pic of my 1533, I marked the spot where the extra holes I am talking about. So if I wanted my 3pt to go down farther I would use the holes closer to the tractor.
   / ? about GC2310 and depth of york rake #6
   / ? about GC2310 and depth of york rake #7
MrSteve, I looked at the 2310 lift arms and they only have one set of holes, I suppose you could drill two more inboard ones. My question to ad11ad is, why are you trying to lower the rake below grade, I thought the rake was held at grade to level and collect debris.Perhaps a box blade would be used with scarifers to loosen objects. Many have said that gauge wheels on a rake are the cats meow, they keep the rake from digging in,alowing you to level the surface.
   / ? about GC2310 and depth of york rake #8
I was trying to pull some roots on a area I just cleared and the rake was only going an inch or 2 into the ground and the roots would just slid out. But I made some adjustments and it is working better. I do have a wheel but it is a single wheel and it works ok but not sure it was work the extra money. A friend as a two wheels on the outside of the rake and I like the was his works much better.
2024 Frontier FL1061S Hydraulic Flail Mower (A56438)
2024 Frontier...
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
19010 (A55851)
19010 (A55851)
30ft Highway Trailer Co. Lowboy (A56438)
30ft Highway...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
2014 Freightliner 105' Bucket Truck (A56438)
2014 Freightliner...
