About the ATI Tach-All Skid Steer Quick Attach
   / About the ATI Tach-All Skid Steer Quick Attach #1
Rolando
Platinum Member
Northcentral Florida
Bobcat Toolcat High Flow Turbo C-series
Since the tractor I am concentrating on now is the B3030, and Kubota doesn't make a skid steer quick attach for that model like they do for the L30's, I've been looking at what is available in an after-market product.
I'm going to need to switch a fair amount between the bucket, a pallet fork and a root grapple. I've read several negative posts about the Kubota pin release set-up, and the choices available in implements will be more limited than for the skid steer system.
Back when I was looking at the BX23, ATI told me the Tach-All for that model loader weighs 33 lbs., which doesn't seem like too bad a weight penalty. I image the LA403 version will be heavier.
I wanted to know what experience folks have had with this ATI product on the 2910/7800 and similar size tractors, and what opinions you might have.
If you want to learn more about it, here is the link to the <font color="red">ATI Tach-All</font>.
   / About the ATI Tach-All Skid Steer Quick Attach #2
When I inquired about the Quick Coupler at the dealer last week. I was told the New B2365 will work similar to a Skid Steer Coupler.
Is 'B2365' the part number for the coupler?
   / About the ATI Tach-All Skid Steer Quick Attach #5
Rolando
Yes, B2365 is the correct whole goods number for the quick coupler on the LA403 loader, but it works with two pins instead of the two levers on the skid steer coupler.
Lewis
   / About the ATI Tach-All Skid Steer Quick Attach #6
<font color="blue"> it works with two pins </font>
Does this mean it is similar to the L2097?
Oops! Thats the Pallet Fork frame number.
Quick Hitch is L1716.
   / About the ATI Tach-All Skid Steer Quick Attach #7
There is no SSL compatible QA for that loader. Its just too small to be useful. There should be a Kubota coupler available. Its a pin type QA, just the ATI.
Neil,
I'm assuming you mean there is no SSL compatible QA for that loader that is made by Kubota. The ATI Tach-All connects to the loader by whatever means, perhaps the Kubota pin, but then the Tach-All is SSL compatible.
I've attached a picture from their web site and you can see the lever set up of the SSL attachment. Their web site states: "Having the Tach-All Quick Attach also allows you to rent readily available skid steer attachments to use with a compact tractor"
Here's another picture from the ATI web site.
2022 Deere 325G (A47307)
2022 Deere 325G...
More info coming soon! (A44572)
More info coming...
1999 Doosan 35kW Towable Diesel Generator (A45336)
1999 Doosan 35kW...
2119 (A46502)
2119 (A46502)
2006 Jayco Trailer, VIN # 1UJCJ02R761SU0073 (A44391)
2006 Jayco...
2011 PETERBILT 365 WIRELINE TRUCK (A45333)
2011 PETERBILT 365...
