about to change hydraulic filter . . . what's in my bx?
   / about to change hydraulic filter . . . what's in my bx? #11
My local dealer says Kubota only allows UDT for refill after warranty work. In fact they don't even carry SUDT. I believe they are advertised as being fully compatible to mix. Since you leave several quarts in the system when you change the fluid, and in attachments (FEL etc) they almost have to be compatible. That being said my BX 1860 whines loudly on UDT, and I intend to try SUDT at my first change.
   / about to change hydraulic filter . . . what's in my bx? #12
That is a curious statement. So you are saying they are shipped dry with no fluids in them? They are not test run at the factory? How do they load/unload them on the trucks to ship them?
Every Kubota that I have seen except for the Larger M series, come in metal shipping crates/skids. Some of the L series also do not have the left hub on so as to fit inside the crate, so they do not have fluid in the front axle either. Not sure about the main gearbox though it may be filled.
David Kb7uns
   / about to change hydraulic filter . . . what's in my bx? #13
My manual calls for SUDT, so that is what I put in it. Then I steer clear of all the UDT vs. SUDT vs. other brand debates. :D
   / about to change hydraulic filter . . . what's in my bx? #14
1* In fact they don't even carry SUDT. I believe they are advertised as being fully compatible to mix. Since you leave several quarts in the system when you change the fluid, and in attachments (FEL etc) they almost have to be compatible. That being said my BX 1860 whines loudly on UDT, and
2*I intend to try SUDT at my first change.
1* and 2* IF you can find it anyplace.
I ran into that problem the last time i was to my local dealer .
Never was a problem there from 2004 -2009.
2012 COMPTANK  ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
DIXIE CHOPPER BLACK HAWK HP ZERO TURN MOWER (A54757)
DIXIE CHOPPER...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
24630 (A55853)
24630 (A55853)
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A53421)
2017 Toro Z-Master...
