About to pull the trigger on a new welder
   / About to pull the trigger on a new welder #21
"I'd go with OTC, Sanrex, Lorch or Fronius."<<<<The only one I heard of is Fronius, now I have to look those other one's up and I was tired of tracking stuff down to............
At my work we use a lot of these, like somewhere around 200 of them, maybe more>> Miller MIG Welders - MIG Welding and GMAW Welding Machines - MillerWelds
and some of these, maybe 50 or so, and that's not even counting the seperate wire feeder, can anyone say ouch>>>>>>>> Miller MIG Welders - MIG Welding and GMAW Welding Machines - MillerWelds
   / About to pull the trigger on a new welder #22
Wow those are production machines indeed! Love that pulse MIG feature to lay your stack of dimes.
   / About to pull the trigger on a new welder #23
I just upgraded to a used xmt304 with 24a feeder and a Optima pulse module, haven't has time to play with it much but so far love the pulser, wanted a mm 350p but that was out of my price range.
   / About to pull the trigger on a new welder #24
I have the same feeder on my XMT 350. Let us know how the Optima works. I was hesitant to purchase the pulser because of the cost plus the reviews on how finicky it was to set up.
Instead I SOLD the 30A spool gun and 24C controller and for the added cost (I WOULD have spent) on a new Optima module I was able to purchase a low hour MillerMatic 350 P. I haven't tried it for pulse on steel as I leave it set up for aluminum.
Terry
   / About to pull the trigger on a new welder #25
At the shipyard, the xmt304 was the first Miller setup 20 years ago, needed a separate control box for pulse but not needed for spray arc. Pulse is required for vertical down and works better for vertical up. Then they went to 354mp mod. and now the xmt 350, no separate control box needed for pulse on those two.
I see that most of us here can only afford the big space taking welding units, but if one has the $$$ these two together with 25'-50' harness is the best setup, lot more portable in abstract conditions......
SuitCase(R) 12RC Wire Feeder | Miller - MillerWelds
XMT(R) 35 Multiprocess Welders | Miller - MillerWelds
Happy Resurrection day, Luke 24
4 And it came to pass, as they were much perplexed thereabout, behold, two men stood by them in shining garments:
5 And as they were afraid, and bowed down their faces to the earth, they said unto them, Why seek ye the living among the dead?
6 He is not here, but is risen: remember how he spake unto you when he was yet in Galilee,
   / About to pull the trigger on a new welder #26
I'm sure Miller suitcase feeders are good but I've never tried one. In my area Lincoln LN 25's are more commonplace.
Terry
   / About to pull the trigger on a new welder #27
Terry
That looks like a good wire feeder setup, does the wire go on the other side? looks like this side is bolted down.
   / About to pull the trigger on a new welder #28
Correct. The other side.
Terry
   / About to pull the trigger on a new welder #29
Wow Big Barn, that Lincoln wire feeder is totally different, wire loads on other side, the gun points downward, never seen one like that very unique. Do you bother with a felt wire cleaner? Usually not needed if only takes month or two to go through 10# roll, for me, most of the time I get 6 month-ish on a 10# roll so I have a wire cleaner on mine.
   / About to pull the trigger on a new welder #30
Regular Pulsed Mig is cool but Nothing like Twin Pulse Digital High Definition that can be set up like a Tig unit. Miller is way behind and Lincoln will likely get there 1st. Fronius, Lorch and OTC are 10 years ahead of USA companies. And for the record. it's painful to say that but Miller and Lincoln have been pushing back on this technology. Just for grins look up Lorch 320SP and see what it's capable of.
WOODS 9021 BATWING MOWER (A60430)
WOODS 9021 BATWING...
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
2018 KOMATSU PC138USLC-11 EXCAVATOR (A60429)
2018 KOMATSU...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
