For portability and light fabrication work, I love my Porta-band. Its a hand-held 4.25" throat bandsaw. Anything soft enough to saw, it cuts.
When cutting aluminum which would otherwise gum up the teeth, or to extend the blade life, you do need to apply a little cutting lube which can be a bit messy. By cutting from both sides, and/or angling the saw a bit, you can get through profiles a bit bigger. I cut some 1x12" steel plate on one project I was working on which would have been a PITA (if even feasible at all) using my abrasive chop saw.
There is an optional base/stand/vise for this saw which sounds really handy, but for most things I do, just marking the piece with a straight edge and a steady hand will suffice in accuracy.
As I said, it is hand-held (with carrying case), so you can take it anywhere you have power. The handiness of being able to cut things "in-situ" when re-working or modifying something big like a trailer, dock equipment, tractor attachments, is a huge win. Even just cutting larger lengths of stock in the shop, its handy to bring the saw to the stock where it is stored rather than to wrestle a 24' piece of stock into a fixed saw just to cut the 1' piece you need.
As others have pointed out, for hardened steel, a band saw will not work, and an abrasive saw is going to be the right choice, but for most things I do, this small band saw is the right answer.
- Rick
- Rick
