AC Options, Mini Split?
   / AC Options, Mini Split? #21
We had a mitsubishi mini split installed at the Cabin a 4n1 and my only complaint is that there is never shuts off the fans blow constantly.
This is a complaint many have, but it needs the air circulation to monitor the temperature and reduce temp swings. I have the fan on mine set on auto and when it is not heating/cooling, the fan speed is so low I don't hear it.
On either the Mitsubishi or Trane, I thought it measured the temp through the remote control so it maintained the temp where the remote was and not the blower?
   / AC Options, Mini Split? #24
Not with the Mitsubishi, the temp sensor is in the unit not in the remote. I was also under the impression the temp sensor was in the remote until I bought one. My installer quoted me about $600 to add a remote thermostat to the unit.
   / AC Options, Mini Split? #25
Mitsubishi Electric US, Inc. Cooling & Heating | HVAC put in your zip and it spits out a bunch of contractors.
I have a Mitsubishi in my attic converstion office. I love it. Previously, the central HVAC could not keep up well (thermostat is downstair). Once I put in the Mini split, it was a significant improvement.
It did cost me ~$4K, but I had a difficult install--~50 ft from the outside compressor unit + a bucnh of other issues.
   / AC Options, Mini Split? #26
Does anyone know if there is a distance limitation on how far away the compressor can be mounted from the unit? I may have a long run when I install mine.
   / AC Options, Mini Split? #27
Yes there is a limit, I think ~80'. My MSZ-FE18NA Mitsubishi has a 61' run and it works fine so far.
Pull-Behind Smooth Drum Ballast Roller (A52377)
Pull-Behind Smooth...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
UNUSED Safety Work Gloves (A53117)
UNUSED Safety Work...
2011 FONTAINE 48 FOOT STEPDECK (A53843)
2011 FONTAINE 48...
