Accidental Mixing of Oils
   / Accidental Mixing of Oils #11
</font><font color="blue" class="small">( Sounds more like a ship! )</font>
That's what I always thought, too, so I was surprised to see a boat with a bow thruster at a dealer's place at Lake Lewisville a month or so ago.
   / Accidental Mixing of Oils #12
Oh, this was on a boat. I thought he had some fancy new tractor! /forums/images/graemlins/grin.gif
   / Accidental Mixing of Oils #13
Jim, I would let it fly or float as is ,it won't hurt anything in such a diluted state.
Do a test for yourself take a quart of hydro fluid and put in a pint of oil let stand to see if it settles to separate, if it does shake or stir if your prefer to see how it mixes as will be the constant state when in use in DAS BOAT, Maybe Unc just invented hydroil /forums/images/graemlins/blush.gif
I wouldn't worry about it.
   / Accidental Mixing of Oils #14
Bow thrusters on da tractor...that would keep the tractor from tipping over sideways when working on a hill. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Accidental Mixing of Oils #15
I like Nasty135's answer. You might also want to heat the mix up to around 200 F and then let it cool to see if anything develops.
Generally, engine oil, unless it's synthetic, has about 20% additives in it. Hydraulic oil likely has very little to no additive. If the hydraulic oil is more like auto trans oil, its viscosity is about 5W. Otherwise, it's a little heavier and maybe more akin to engine oil weight, which is 5 to 40 weight, generally.
I'd say the inadvertant mixing should cause no problem, but I'd be wanting to change it out at the next opportunity.
Ralph
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A54313)
2017 FREIGHTLINER...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2012 CATERPILLAR D6T XW HI-TRACK CRAWLER DOZER (A51406)
2012 CATERPILLAR...
