Aching for the bacon...
   / Aching for the bacon... #11
+1 on the apple. If my apple wood is seasoned, I try to soak it in water for a day or so before throwing it in the smoker.
Then there's the old favorite around here, slabs salted down heavy, then hickory smoked
   / Aching for the bacon... #12
I always soak any smoking wood in water to keep the flames away. I have tons of clean cherry shavings from the planer now and water brings the aroma back nicely. Apple/cherry/hickory all work nicely. My mesquite is now limited to a nice steak since its distinct flavor tends to overpower anything else.
One thing I intend to do is cut some of the wild berry canes and try that to see what happens (soaked of course). Waiting for a piece of meat that I wouldn't mind throwing away if it doesn't work.
Thanks all... actually I eat very little bacon - give most of it away. I did a lot of research on the web, bought a few books and asked around.
One of the challenges, for me, is to avoid nitrates. Most commercial products you buy, Salt 1 or 2, Prague salt etc. contain it and it is nasty stuff. Used in small amounts it does its job but it is deadly. My challenge is to not use it. I use a recipe of 1/3 salt, 1/3 brown sugar and 1/3 maple syrup. I brine the portions in zip-locked bags for a week, turning them over daily. From research, you can freeze the end smoked product for about 6 months, but you must consume the bacon in 2-3 weeks when stored in the fridge... not an issue. The cold smoke system allows you to control smoke and temp over 2-5 days. The building is not air-tight. Some buildings have controlled vents. I left the eves open and enough cracks to let the smoke through. **** Remember this is all new to me and a huge learning curve.*** The fire box is 8-10 feet away from the house. Mostly 6 inch ss pipe. I use apple wood and pruned branches from my trees but I do have access to pear trees, cherry and plum on my land - so over time I may try them all. Stay away from the coniferous woods. I got the internal temp of the bacon slabs up to 100+ degrees and smoked for about 6-8 hours. Some research info says 80 degrees, some say cook it at 150... I usually take a slice off and try it. If it is not smoked enough you can always continue. So long as there is smoke coming out it is working. Because I gave up salt years ago I do find it a bit salty. I took one piece after smoking and let it sit in water overnight and drained and tried a piece. The sweetness and smoke is there but not the salt - this I prefer but my friends don't mind the salty taste, so I guess you can fine-tune as you go. I will try fish next and some cheese as well. Some people are smoking pepper, salt and other spices for added flavour. A ton of info out there... I did do some hot smoking over the years with great results. I bought a hot smoker from local hardware store... it looks like R2D2. Simple but works. Hopefully I have answered most if not all of your questions. Along with the pizza oven build - this is another thing crossed off my bucket list! Cheers... PS: you all need to do this!!!! And yes to do need to tend the fire.
   / Aching for the bacon... #14
a cold smoker, u lucky bugger. cheese/fish and bacon. mmmmmm
p.s. make sure no critters have made homes in the up-pipe
   / Aching for the bacon... #15
Speaking of bacon, anybody ever tried cooking bacon on one of them George Forman grill contraptions?
Looked at one the other day at a garage sale, seemed might be a little small, but looked like you could cook some bacon on it and keep it from wrinkling up.
   / Aching for the bacon... #16
The kids gave us one of the large George Forman grills several years ago. I tried burgers and chicken breasts on it, but they were too dry to eat, so it went back on the shelf for a year or so. For some reason, I took it out one day and threw some bacon on it and voila (that's French for Shazam!), darned good bacon. Cooked just right, all the grease drained away and the bacon was perfectly flat, just like using a bacon press. Right now, bacon is the only thing that it's used for, and that's the only reason we still have it.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
3650 (A47477)
3650 (A47477)
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
John Deere 1025R (A53317)
John Deere 1025R...
2022 Horizon (A55973)
