Adapt moldboard plow to TPH
   / Adapt moldboard plow to TPH #1
CFHartman
Keyser WV
John Deer 2210
Has anybody adaped a ten inch plow to a TPH. I've ordered a JD 2210 and traded my JD 214. I want to use the plow this spring and later on I may get a tiller. I have a walk behind tiller but it is very old. My hitch on the 214 was called a lift hitch.
Thanks if you can offer any help
Charlie /forums/images/graemlins/tongue.gif
   / Adapt moldboard plow to TPH #2
Do you have a picture you can post?
Should be able to weld a converter bracket that will fit both, either yourself, if so equipped, or by taking to a welder to help you do it.
Beenthere- I took a picture of the plow. I don't know how to reduce the size so I can attach it
Charlie
   / Adapt moldboard plow to TPH #5
Download a free program called PIXresizer here
It will work wonders with one or multiple pics.
   / Adapt moldboard plow to TPH #6
Here is what I did for my 10" plow. I used to use it on my Cub Cadet that had a sleeve hitch and now use it on my BX. Here is an old post of mine when I plowed my Garden a couple years ago that has some pitctures of my setup.
Plowing with my BX
Thanks a bunch Randy. That is what I have been looking for.
now I can get started gathering the materials together to build it
Thanks again
Charlie /forums/images/graemlins/smile.gif
   / Adapt moldboard plow to TPH #8
Your welcome. I also had the 2" reciever hitch built after looking at other ones on this site. I liked the idea of using that hitch for other things like moving my trailer, and my cargo carrier if I wanted to.
I built my adaptor with the stop on one side for the plow and the other side without so I could use it for attaching my garden cart as well, but have since added a stop on both sides and eliminated the potential use of the garden cart to the 2" reciever hitch.
I found it gave better support to the plow and I don't use the garden cart much since I have the loader now /forums/images/graemlins/grin.gif
   / Adapt moldboard plow to TPH #9
Nice Job!
Wow, I thought I was the only one to make one of these things /forums/images/graemlins/smile.gif. I did the same thing as you, I made the 3pt to 2" receiver and then a 2" receiver to sleeve hitch. Very cool. I made mine to use some forks I made for a winch powered sleeve hitch on a GT.
Kurt
I'm experimenting with resizing photos.
RIDGID 141 THREADER (A53843)
RIDGID 141...
Peterbilt 377 Semi-Truck (A53473)
Peterbilt 377...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2011 JOHN DEERE 670G MOTORGRADER (A51406)
2011 JOHN DEERE...
PIPE WRENCHES (A53843)
